two neutrals on an outlet where the hot tab is separated?
Terry D
St. Louis, MO.
I'm taking each receptacle is going to be a separate circuit. If it is a MWBC (2 hots sharing 1 neutral ) then no, you don't break the neutral off. But if you are having a separate neutral for each hot, then you would break the tab off. You need to feed it with a 2-pole breaker or 2 single pole breakers with a handle tie, so when you you shut one circuit off, the other de energizes also. This is a code requirement for safety
When you say that you are using nearly all 15 amps, what kind of loads are you plugging into it
L
luvit
12A each.. i ended up breaking the neutral and operating each outlet in the receptacle as a 15A independent plug. Thanks for the confirmation.. I didn't like that information I read earlier last night.
