exploringnh
- Joined
- Dec 6, 2015
- Messages
- 16
I installed my lift about 9 months ago. It's a two post ground plate lift, 9klbs. I forget the exact details of the concrete but it exceeded the specs required by the lift installation information but not by much. The lift has been used daily for the last 9 months. The manual called for a torque spec of 85-110ft/lbs. I initially torqued them to 95ft/lbs. They all torqued nicely with nothing unusual happening.
I check the bolts for torque occasionally, about every 3-4 weeks.
Every time I have checked the anchor bolts, they have taken torque. The first couple of times they spun up to 180* before reaching 95ft/lbs again. recently they seem to be taking less and less. I torqued them again today and to hit 95ft/lbs none moved more than about 30*. I marked the bolts/nuts to see if the nut was backing off or if it was in the anchor. The nut stays in place on the bolt, so it is the anchor itself that is loosening, possibly compressing the concrete? There are no signs of cracking in the concrete or anything else. Everything looks like it should.
Is this a concern? Should I crank them down to the full 110ft/lbs?
