Two similar air compressors, which one is better?
chazzz
Republic of Southern California
I have narrowed down to two air compressors:
Husky 30 gal 155 psi ultra-quiet portable air compressor
$399.00 @ Home Depot
ASME certified tank
6.2 CFM @ 40 psi
5.3 CFM @ 90 psi
15 amps
Can run on either 110v or 220v
1.6 horsepower
Central Pneumatic 29 gal 150 psi
$359.99 at Harbor Freight
ASME certified tank - unknown
7.3 CFM @ 40 psi
5.9 CFM @ 90 psi
13.8 amps
Strict 110v only
2.0 horsepower
I understand that Husky air compressor will run better using 220v. Central Pneumatic is slightly more powerful than Husky, but only uses 110v. Both have cast iron pumps (oil lubricated). Husky have two cylinders. Central Pneumatic has only one cylinder.
I think Central Pneumatic electric motor and air pump were made in USA.
So, which one is better?? I am somewhat leaning toward Central Pneumatic because of slightly more power. Help me to decide which one is better.
Angelfire
New Mexico and Ireland
Be careful with HP ratings.....manufacturers can butcher them. The Husky draws 15A and the CP draws 13.8A.....how is it the CP has more power? I doubt the efficiencies of the motors are that different.
ptgarcia
Alta Loma, CA
Based on the information provided, horsepower numbers for the Husky are questionable. I'm not sure how they came up with that 1.6hp figure.
Husky: 15A at 220v = 4.4hp or 15A at 110v = 2.2hp
The Harbor Freight unit looks ok:
Central Pneumatic: 13.8A at 110v = 2.0hp
raferguson
Colorado
Horsepower ratings for compressors are fantasy numbers, to be ignored. The motor amps are probably the best indication of horsepower.
I would note that the unit that draws fewer amps claims more cfm, which seems unlikely.
I am not a fan of any 110V compressor, they will not run sanders or grinders. I suggest you look for a used 60 gallon 220V compressor, typically around 15 amps, which will put out twice as many cfm. These are pretty common. I started with a top of the line 110V compressor, very frustrating, switched to a 60 gallon 220V compressor, now have an 80 gallon compressor that pulls 23 amps at 230 volts. My current compressor will keep up with the air tools that I use. The 60 gallon was not terrible, but sometimes I had to wait while the pressure built up in the tank.
Your 110V/220V compressor will be no better than a 110V compressor in terms of output
(220V, 230V and 240V are different ways of describing the same thing, as far as I can tell).
fsae0607
San Fernando Valley, CA
Beware of that Husky one. I have the same exact compressor and two motors crapped out on me. on the home depot site for that compressor, scroll down to the reviews and look from the one by "Javi" to see what I did to it.
After the second motor crapped out, I bought a Baldor 2 HP motor and ran it on 240V as the Baldor is a true 2 HP and would trip the 20 amp breaker when it started up with pressure in the tank.
C
chazzz
I don't really need a 60 gallon air compressor. I don't plan use heavy duty air tools. That is why I am looking for a 30 gallon air compressor which is good enough for me.
6768rogues
Western NY
I never thought anything from HF was better than a similar item anywhere else. I don't know about Husky, but you will never get parts for one from HF.
PWC Repair
Arkansas
Id go with the Husky cause its twin piston, not to mention easy to get repair parts down the road. Or if you're concerned about noise at all check out the California Air compressors.
rpthack
SC
I have that Husky. No complaints with relatively light use (impacts, ratchets, light grinding/cutting, etc.). It would prefer 220, but does fine on 110 for light stuff. If your demands aren't high it's pretty capable for a light duty comp.
C
chazzz
I'm not concerned about noise. I've seen some California Air Compressors, but they are oil-less. I'd rather to go with traditional, oil air compressors because they last longer.
Thanks
C
chazzz
Harbor Freight Central Pneumatic electric motor (2 hp) is manufactured by Marathon Electric, an American company but it was assembled in China.
Does anybody in here knows about the pump? Was it made in USA?
I'm referring to Harbor Freight item #61489 29 gallon, 150 PSI MAX.
Norcal
110 ,220 are obsolete pre WW II voltages, 115, 230V are the rated voltages for motors & welding equipment, 120, 240V is the current nominal voltages supplied by the power companies.
C
chazzz
I just found out that Quincy 26 gallon air compressor (Model Q12126VPQ), 2 hp compressor pump is very similar to Central Pneumatic's 29 gallon compressor pump. They both are cast iron, but the heads are made of aluminum. Quincy said that it should last 10,000+ hours (rating). Northern Tool is selling it for $659. I can get similar one from Harbor Freight for only $359, $300 savings in my pocket. Both are very similar, but Quincy produces 8.3 CFM at 40 PSI (HF is 7.3 CFM @ 40 PSI).
WhiffySpark
I highly doubt the hf is anywhere close to Quincy. Don’t let those harborfrieght VS the competition ads get to you
I would buy husky. I won’t buy anything that use electricity from HF
fsae0607
FYI. I also plumbed it into my hard lines. The regulator it's supplied with is junk since it restricts air too much. The way I have it installed, it keeps up well enough with impacts and grinders.
JRC3
Southwestern OH
The Husky has a 2 year warranty. HF is 90 days. That's all I have to read.
The Husky advertises 75dbA and someone else around here said the HF is around 83. Not sure how accurate either of those numbers are.
NewShockerGuy
Northern Virginia / DC
The Husky posted above looks exactly like what Lowes was selling as Kobalt a couple years ago.
I have a Husky that is the Campbell Hausfield rebrand that is probably 6-7 years old now. (taller red 30 gallon one). I would have loved to have a 60 gallon but zero room in my tiny two car garage so a 30 was perfect plus it has wheels and I can move it about.
Change your intake silencer to a better one and it will quiet the compressor down significantly.
Pic of what mine is:
-Nigel
blake101
Columbus, MS
Most of all of your smaller air compressor pumps are made in China. There are a select few that aren't but the price on them are usually $300 - $500.
6768rogues
Western NY
And a Yugo is very similar to a Cadillac.........they both have 4 wheels.
rpthack
SC
The Husky, from my research, is just a CH that's sold at least at Lowe's, Tractor Supply, and HD.
CompressorPros.com
SC
Beware of hour life ratings. That typically only applies to the main bearing, which really shouldn't wear out anyway. Valve, gaskets, rods, etc. are under more stress and will fail. Hour life is a point of sale eye catcher, that's all
