I havent read the earlier thread, so this info may be in there, if it is I apologize, but what kind of hearters are those and what are their ratings as far as sq/ft.? Thanks, and OSB FTW. Awesome build.
No problem, I can't remember if I did mention them or not, but they are Ductless Split Systems. They are common virtually everywhere but the States. I first saw them in Mexico. We owned a house South of Guadalajara and I became intrigued with them there. I have one in the upper room and one in the shop area. The following is what the manufacturer say..................
18,000 BTU - 13 SEER - R410A
[Cooling + Heating] 500-700 sq ft
A practical alternative to the expense of central air conditioning, as well as an aesthetically pleasing alternative to window or through-the-wall air conditioners. A streamlined and light-weight air handler is mounted on the inside wall. Refrigerant and condensate lines run through a small hole in the wall to the outside unit. Initial power is to the outside unit and then relayed to the air handler. Extremely quiet as the compressor and condenser coil are outside. Full electronic and remote control.
