Ty Wrap Holder....
tmunsch
Baytown, Texas
Did a search, turned up nothing....
What are you guys doing to hold your ty wraps. I have many sizes and they are always bundled together and not very organized.
What I am looking for is something that could hold several sizes and lengths and is semi portable. I could set it next to where I am working and use different sizes as needed. Something like round tubes attached to a bar or stand...
T,
southalabama
Brewton AL
When searching best use google not the search from the board
Put in google
Garagejournal (whatever your hunting)
ebmiller88
For smaller, 6-8" or so wraps I use a discarded Parmesean cheese container, one with the lid with shaker holes on one side. For longer ones up to 12" I'm using a "Pub Mix" container from Sam's Club. These work great for me. Others have used PVC pipe and caps cut to length for a more custom look.
Ed
sixleaker
Chico, CA
I use PVC screwed to a scrap board.that way you can add as many,or a few sizes as you need. It's cheap and easy, but still keeps them handy.
JakeKohl
Greenville, SC
I use ty wraps to hold my ty wraps. I bundle them by size and type and wrap one of the matching ty wraps around the bundle. As the bundle gets smaller, I keep cinching up the ty wrap.
pepi
Woodstock, GA
I leave em in the bag, take the bag too the work. That way I do not run back and forth to a location hanging on a wall somewhere. Always have what I need and when done they are already stored, I know to simple.
Sleepr66
Oakville, ON
And use different terms. I've never seen them spelled ty wrap. I have seem tie wrap and zip ties.
Always been zip ties to me as well. Back in the days at the race track heard a few people refer to them as zap straps too. :dunno:
T
tmunsch
Baytown, Texas
Zip ties, tie wraps, zap straps...whatever...Panduit and T&B call them ty-wraps, that's how we have always spelled it in the trade.....I searched it several ways, even in Google an still didn't come up with what I was looking for.... I though maybe...oh well... :dunno:
I guess I'll have to get creative and build something portable and lightweight...thanks for all the suggestions, links and spelling lessons.... :lol_hitti
T,
Fred W B
Port Elizabeth South Africa
I just use a holder sold to organize pencils/pens etc on a desk. I put some sections of aliminum pipe inside the tubes to better support the longer zipties.
You can see it in this picture
TEXACMAN
Mount Pleasant Texas
If they are loose I bundle like sizes and use one to bundle together , tighten it as you use them. I keep the bundles in a Klein zipper bag . If they come in a bag I make a slit in the top to get them out , roll up bag and wrap rubber band around it to keep them from falling out.
SALIV8
chicago and s/w michigan
This is exactly what I do. I keep all the wraps facing the same direction and pull from the female end. I haven't had any problems this way yet..
TheOtherChris
SE Idaho
Not mobile. Like others I used PVC pipe but I angle cut the bottom so it would fit flush against the wall when mounted to the cabinet because I didn't have any caps handy. The little one has a wooden plug in the bottom.
bullfrog123
SE Idaho
Harbor Freight jobby. Sure you could build one easy enough. Simple square tube and a pc of flat plate with a bend on the top to hang onto the toolbox, tool cart, or whatever else. Small and compact. The bags are in a tub in my toolroom so refill as needed.
Falcon67
Merkel, TX
Gallon plastic bag, thrown under the bench. All colors and sizes in there. When I need them, I just take the bag or throw it in the tool pouch.
skcj213
Southern Illinois
FWIW - Ty Rap is a name trade marked by Thomas & Betts for their cable tie products. Over the years it came to be the common name for cable ties in general. Kind of like Kleenex for facial tissue or Band-aid for a self adhesive bandage.
Just a nugget of knowledge for those interested.
Beemer533
Syracuse, NY
Zip ties make a zip noise which is bad (plastic retainer).
Ty wraps are silent and are a lot stronger (steel retainer).
http://cabletiesunlimited.com/ty526m.html?gclid=CI70_7Pq_L8CFSgV7AodQTYAPw#.U-Es6lFa2kw
Ty-rap is actually a T&B brand name (sort of like Kleenex is used instead of the generic word "Tissue")
And while I agree that the metal tang versions are stronger, that isn't always needed. Those aren't cheap...
There are many different brands/manufacturers of the all plastic ones and a lot of them are total junk, but there are some that work just fine. The Panduit brand comes to mind as some good ones.....
EDIT: Whoops, a bit slow... skcj213 beat me to it..
T
tmunsch
Baytown, Texas
This is what I'm looking for...what is the name of this harbor freight jobby....
FWIW guys, I have the plastic baggies....a bunch of them...in my drawers.....all over the place...
Looking for an organized solution like bullfrog and greenyj posted where I can pick out the one I want at a glance and just keep it refilled...thanks for all the suggestions....
T,
Bogey won
TEXAS
My pard bought a handful from HF and when tighten up they snapped in two, he was not happy, ive bought some an not had that problem yet, and i keep them in a drawer in bags, but in some sense of the word they taking up space what could be use d more productively.
Aquamoose
Spent 20+ years using them as a professional emergency vehicle up fitter. Keep it simple, I bundle exposed bags with its own wire tie. Easy, simple, cheap, & portable.
