I'm rebuilding my garage using the old 12' x 18' stem wall foundation, and I want to extend the length from 18' to 24'. Obviously I need to tie in the new footing / stem wall with the existing concrete. I thought I could anchor two or three pieces of 1/2" rebar horizontally into each side of the old concrete with epoxy and coat the face with concrete bonding adhesive before pouring the foundation extension, but I'm concerned that this won't be adequate. Most information I've found online says, "Talk to an engineer." Before I call the pros, I thought I'd check if anyone around here has seen or done this.
This will be a detached, single story garage to be used for storage and as a workshop (no vehicles inside).
I've attached views of the front and back of the foundation. The gray concrete is the existing foundation, and the red is what I want to add. I should mention that I didn't include the footing in the sketches, just the stem wall.
Thanks!
Thanks!
