Guys, I'm try to get a wall in my garage ready for sheet rock. I have a 10ft wall with scissors trusses. The gable end is above the 10ft area of the wall. When my builders built the wall I noticed the gable sits flush with the outside, but not inside. I ended up adding some 2x4's and plywood to fill the gap between the gable and the wall. I also added 2x4's at the same angle as the ceiling joist. This will let me run the sheet rock all the way up to the scissor trusses.
With all that said, I have a little movement in this wall when I shake it. Its mainly in the gable area. What I want to do is tie the gable end to to the truss beside it every 24 inches. The trusses are on 16ft center. I put two braces on each side and its definitely made a difference already. My big question here is when tying them together does it affect the engineering in the truss? Here are a few pics:
Thanks, Russ
Thanks, Russ
