Type K, M or L copper for air lines?
Blk88GT
Manitoba
I never paid much attention to this when I did the lines in my old shop, but was wondering what I should be using in my new place.
I'll have a half dozen drops, done in 1/2" copper. Compressor does 125psi, maybe someday I'll go to 175.
Thanks in advance. :beer:
KenC
oklahoma
Search for 'copper tube handbook'. Official pub from the copper industry. Lots of good info, pressure ratings, temp rating etc.
IMO, stay away from M, either L or K will be fine. The joints are the weakest point and the best solution is a silver bearing solder but I've used lead free with no problems. The compressor to building pipe connection should be flexible to both isolate vibration and heat. I used a hydraulic line.
Blk88GT
Manitoba
After looking at the document pattenp linked (thank you!) I don't see why I wouldn't use type M.
CNGsaves
KS and OK
Discussed many times in recent GJ threads. Good luck in your build.
Use Advanced Search for:
. . . . copper airlines
KenC
oklahoma
I should have been more clear in my preference not to use M. It is rigid. All changes of direction or plane must be made with fittings. The others can be bent without kinking. So minor offsets can be made by bending. Even 90deg bends, like dropping down a wall after traversing a ceiling, can be done without fittings.
So even though the thicker L/K cost more, if several fittings are needed using M, the overall cost will be less. And, the time is much reduced. As well as your frustration, if you like sweating fittings as much as I do. I wouldn't even consider mechanical fittings, (flare or compression).
djjsr
In the cornfields
You can safely use M copper. It will easily withstand the pressure of any garage compressor. Reference the tables at Copper.org.
G_P
Central CT
Type L is also rigid tubing.
I've used type M up to 125psi soldered with standard plumbing solder with no problems.
Buying rolls of copper tubing is going to be a lot more expensive than using rigid tube and fittings. Buy fittings at a big box store. Small hardware stores tend to have insane high prices on fittings.
Sent via carrier pigeon.
Lhorn
Pretty sure mine is M. Got it at Lowes I think. Soldered joint. My pressure is limited to less than 100 psi just because that's what I need.
flat350
illinois
Copper is normally priced the same per foot to the wholesaler be it in 20' hard lengths or soft rolled, 1/2" L hard would be the same $ as 1/2 L soft.Type K is difficult to locate in hard lengths.The job will look much neater and clean using hard with fittings over soft and bending it,you'll never get the soft copper as straight as it is in it's hard form and you may find type L will withstand a little more abuse from impact than type M will.
maxspeed96ct
If it were my shop and a place id be staying long term Id use L , but there's a ton of M tubing out there that has been fine for centuries and will be fine for many centuries to come.
Just depends on you budget and long term goals.
Hell, you could even use pex if you really wanted to .
Blk88GT
Manitoba
I'm staying where I am forever, believe me! I'm going to use rigid M and/fittings. I'm sure it'll work just fine for my intended use. Thanks everyone!
djjsr
In the cornfields
Soldered joints are plenty strong enough to hold the pressure. Now I'm sure some "expert" will be here shortly to tell you that they could come apart in a fire. My opinion is that if you have a fire that hot, your air piping is the least of your worries.
Bobdog
South Jersey
Only if it's soft copper sold in a roll. Type K and L rigid can't be bent like was implied. It takes a special bender to bend rigid copper.
No it doesn't, I do it all the time. You just have to anneal the copper with a torch and let it cool down.
Bobdog
South Jersey
Also, do you guys solder or braze the sections?
I'd braze them, but you'll be fine with M copper and 50/50 solder.
I've seen refrigerant line sets done this way in the 50's and 60's that are still leak tight to this day and they routinely see 3x the pressure you're talking about.
Kevin C
Portland OR
That's why you wrap the joints with electrical tape.
Bobdog
South Jersey
I want to do K type soldered. Yeah?
Well, if you're going run enough pressure to warrant K copper, then you'd be better off brazing or at the least using a silver bearing solder, such as Harris "Stay-Brite #8".
Additionally, if your application is going to see a lot of vibration, heat, or thermal stress then you'd better not solder it.
