This subject has been discussed many times on this forum. The least expensive air line system is what is used on air-brake systems on big trucks. While this system can be made pretty, it is not good looking, it can be.
The air line can be bought in rolls and many sizes. FASTENAL most likely sell this product. The connecting fittings are also inexpensive and come in two styles. There is the, simple for the installer, push to connect and the other tighten to seal. I prefer the latter.
http://www.pisco.com/products/fitti...8WN1jIMZDHx-x8F3alALiE5OzsZw-ZkRoCYo8QAvD_BwE
If you are going to bury it in a wall then I'd do black pipe.
I used rapid air Maxline.
Pretty easy to hook up. I ran in attic space and did drops to outlets.
I am almost hooked up. I hope it doesn't leak. But I have yet to have a system set.up that didn't. Whether at a fitting or qc. Or the line
I was super careful w this but there are a lot of joints. We will see.
Much easier and cheaper than a bunch of copper.
its actually cheaper to go with maxline system vs buying pex al pex from supply house. its the individual fittings for air line hookups that cost the most from maxline. i did the math and if i were to buy the hookups seperate and get my pex from supplyhouse id be paying more i think close to 40c/ft moreWhy didn't you just run pex from a www.supplyhouse.com?
Uh...i don't know.... maybe because cheaper easier and I would say better.Why didn't you just run pex from a www.supplyhouse.com?
Sent from my SM-G935W8 using Tapatalk
