B_Bimmer
I need this seal for a press and am having a much harder time finding it than I was expecting. Most seem to be much shorter with even close to the same ID and OD. Am I missing something?
I was able to source a metric u cup seal on ebay for a jack I was rebuilding, might try there.
Try measuring the OD with a micrometer. Dial calipers aren't the best choice for what you are doing/measuring; a micrometer is the correct and more accurate tool/instrument.
Nonsense. That digital caliper is fine for that job assuming he knows how to use it.
Calipers are fine for this application - the seals are spec'd as "nominal" dimensions anyway - it's a piece of flexible plastic; I wouldn't be surprised if they vary +/- 0.005". Measuring the rod OD where the seal sits and the cylinder ID is sufficient to specify the seal.Try measuring the OD with a micrometer. Dial calipers aren't the best choice for what you are doing/measuring; a micrometer is the correct and more accurate tool/instrument.
That's for retention of the seal - it's the cheapest way of doing it.Does the cylinder's endcap have any interaction with the seal to change the sealing diameter? It seems odd to me that the end of the rod is mushroomed over on its end, is that a part which contacts workpieces?
I think that's a good solution, although I'm thinking that for a fixed ID/OD, the taller seal will have greater load capacity. But for your application, it may not matter. Do try to leave a small space for the seal to expand, heightwise. Both temperature and exposure to hydraulic fluid will cause that to happen. I can't remember the guideline, but maybe 10% of the seal's height.Now my problem is with the approximately 10mm necked down area on the piston where the seal sits. Since it appears all the seals close to mine are only 8mm high, do you think if I filled the gap below with an o-ring it would keep the u cup from sliding back and forth giving me a "dead spot" in every stroke of the piston?
