I'd bet that under-torqued is a more common issue than over-torqued for the average joeI guess that washer tells you that the nut is torqued to a minimum spec. But it says nothing about being over torqued.
So a castle nut?I think it should be a Federal requirement to have a cotter pin in the ball shaft. I covered more than a few crashes in which the trailer detached from the tow vehicle at speed. Every one of them still had the ball in the trailer hitch, but no nut. Few people know how to properly attach the safety chains, if they are used at all.
doesn't even HAVE to be a castle nut. even a regular nut that can't spin all the way off because of the cotter pin is better than nothing.So a castle nut?
How do you have yours setup? Assuming you tow
Fair point.doesn't even HAVE to be a castle nut. even a regular nut that can't spin all the way off because of the cotter pin is better than nothing.
Multiple ways to do it. Have some experience with homebuilt aircraft and have seen castle nuts on prop bolts. Elastic stop nuts other places or for high heat places a nut sort of like a castle nut but the points are springs that grip the bolt. Might be hard to find those in the larger thread. Seems like a little removable locktite would be simple and effective.doesn't even HAVE to be a castle nut. even a regular nut that can't spin all the way off because of the cotter pin is better than nothing.
It is impossible to spec a torque without knowing the stud size, material/heat treatment. 200 lb/ft would be close to correct for a clean, dry 3/4 UNF stud. If it was a 1" UNF at Grade 8 equivalent strength the dry torque is more like 800. So: the bottom line is go to the manufacturer and get the correct torque and follow the spec. We're talking a range of 4:1 over what you could find on a 2" ball.I don’t want plastic anywhere near my hitch. I use a 24” crescent wrench and get ‘er snug. 150-200 ft lbs and they stay tight. I pull my bobcat all over and lots of firewood.
Referring back to post #6 the words I would have to say about that would be horribly inappropriate in polite company.
Yes, castellated nuts would be nice, or some other positive locking device. So very few safety chains sufficient strength, decent locking hooks and properly installed.
