U-Joint Snap Ring Pliers
ZiggyMacD
Recently did the rear U-Joint on my rusty Torrent. These pliers were a real treat to use. I Had the feeling that they were the perfect tool for clip removal. A feeling that we all are after, one that brings us to this Forum. Felt kinda like the coyote finally getting his hands on the road runners throat! I have been told that they work well for dental work also.
cannuck
Rural SK
What brand? Could you show us the ends up close? Are these meant for the kind that do not use a round hole???? If so, VERY itnerested.
Z
ZiggyMacD
Unique jaw is specifically designed to remove and replace Hotchkiss style snap rings on universal joint easily.
The 75 degree head designed to access those hard to reach areas. Serve as a secondary option to the 70300 Snap Ring Plier.
Features
Used to break loose, replace & remove even the most highly-corroded Hotchkiss snap rings on universal joints
Used to remove Plastic (push-pin) retainers.
Both tools are Applicable for Automotive Vehicles
