matt_i
So when I built my foundation (pad + stem wall 8" above grade) its built with rebar every 16" on center, both horizontally and vertically.
I left one vertical rebar nub, proud, by mistake, about 1/2" proud of the concrete, for lack of execution on my part.
Since then, looking at it, I said to myself I could make this into a ufer ground. I drilled and tapped the center of the vertical bar #10-24 and it has a corresponding hole sawed into the bottom wall plate for access.
Now its about time to close up the walls and I either need to finish this or abandon it.
I have in my mind I would buy a 100' piece of #6 bare copper (stranded) and land it on the bus bar of the 100A sub panel feeding the shop. Its all attached to the main residence and I ran a #2 THHN back to the main house panel so there's no additional grounding required.
Lightning strike protection would seem to be the thing to be after and I do have CNC machines with sensitive electronics plus digital phase converter, those would be the $$$$$ things I would want to protect. That said, I have never had a piece of equipment (PC, TV, router, or otherwise) damaged by lightining strike after living here 7 years.
Just curious about your thoughts as to whether I'm going to get the benefits I think I am by finishing this off? Is #6 enough to shunt lightning to ground or is it going to be balls of molten copper inside the walls?
