bushmechanic
- Joined
- Mar 17, 2014
- Messages
- 4,820
Well, the spring should be cheap.
It's the orthodontist appointment after that will clean you out.
I’ve replaced torsion springs a couple times. This is dangerous work and not to be considered trivial but with proper respect it is fine.
Wear a good heavy pair of leather gloves. Wear eye protection.
I wear and old football helmet as well but a cycling helmet wouldn’t be a bad idea.
Get two winding bars and a good adjustable wrench.
Stand on a stable ladder or chair so you are at a comfortable height.
Don’t stand with your face in line with winding bars. A broken shoulder is better than head trauma.
The wife heard a bang when she opened the garage door yesterday and I found out when I got home that the spring had broken. Based on the number of death warnings posted around that thing I'm not going to attempt a diy job so I'll call a pro. Anybody know what that type of repair runs? I have no idea.
12' non insulated door.
Thanks!
I don’t wear gloves because gloves can slip. Also don’t use an adjustable wrench. Use the proper size open/box end. Usually 3/8 or the box end of a 7/16
Next up is pumping the septic tank. And I ain't doing that myself either.
Not sure how you are explaining this right. How do you adjust the spring when the door is up blocking your access to the spring/drums?
It has to be torsioned while the door is down. In the down position is when the most torque is needed. That torque decreases as the door raises. In the full open position the spring is almost fully untensioned.
The spring is used as a counter balance to the door weight. If it werent present, garage door openers would look more like winches.
I called right after my last post. He showed up at 5:30 that day, right when he said he would. It was only $165. Took him about 45 min. Changed the spring, inspected the door/motor and oiled everything. And yeah, I hate paying for stuff like that but I know it was done right and after watching him I know how to safely repair it myself next time.
Thanks for all the replies!
