Uh..shock from EGO 56V blower?
joseywales
Southeastern, PA
I cleared snow earlier, figured I'd just blow off the dust that fell over past hour. Wearing liner gloves, and ski gloves, I could still a shock coming through when I engage the trigger. I thought perhaps the glove liners were creating some issue, so I tried it bare handed. Sure enough, I'm getting shock. Is it possible that the moist environment of snow doesn't play well with the blower? Never had the issue clearing leaves
J
joseywales
Southeastern, PA
That's what I figured and what it felt like, but it got bad enough I couldn't hold it. My liners are a nylon/synthetic, so they made crazy. I'll try wool gloves next time!
Oh well. Doc wants to do shockwave on my knee next week, so I guess I ready for that!
65ranchero
Danville, VT left NJ forever
That's not static electricity if you can't hold it. Static electricity will discharge once and be done with.
Good point! It needs to be clarified if this is a single static shock when touching or if it is constant with pulling the trigger switch.
Is the OP using a extension cord ? Possible ground issue in the cord? IDK
Viper98912
GA
How strong is the shock? Normally static is just a quick small discharge that gives you a tickle. If you're actually feeling it come through your hand muscles, you may have a different issue with the machine.
paulsomlo
Northern Colorado
I'm not so sure about that - most likely, the motion of the air over the plastic housing is creating a large static charge, again and again. I get a similar effect from my belt grinder - either from air rushing over the belt/pulleys, but most likely from the belt moving over the plastic pulley. And it happens over and over.
65ranchero
The 1st section describes Static discharge and ways to combat it
FredWanaker
NorCal
Static.
Put the leaf blower away for the winter.
that or tie a flexible wire to it and drag it around on the ground when you are using it. See if that helps. Keep an eye on all the garage doors, you may open one with the spark. :)
rlitman
Long Island
Nope. It's static. My Stihl backpack actually has a static discharge system built into it, but lower powered handheld blowers usually don't have or need this. However, snow particles in dry air are really good at building up a static charge.
LS6 Tommy
Northern NJ
X2. Happens sometimes on HVAC equipment with plastic fan blades and blower wheels when the blower motor/hosing is on vibration isolators where there is a weak bonding ground, too.
Tommy
