UK auto transformer conversion.
retireddiy
Hi all, I found a tacima auto transformer at goodwill. Can input voltage wiring be converted to 120vac while retaining 120vac output. If I can I’ll need to figure out how to open it lol. Any helpful appreciated.
PCustoms
VT
Why?
I guess you could gut it and bypass the winding.
R
retireddiy
Thanks for response. Looked up uk to us adapter found one with grounding pin.
dogdog
UK uses 240Vac 50Hz I think, US are mostly 120Vac 60hz. There are transformers that converts 120 to 240vac and vise versa.. but those same transformer will not convert 120Vac to 120Vac... it's kinda of pointless for normal people. But medical industries and some weird people will have the ISOLATION transformer... that is 120Vac to 120Vac and the grounds is not shared or neutral is not tied to ground, something to that extend. for safety means. you can probably google that...
?? US to UK adapters ?? errr... those are not usually or auto transformers so...
PCustoms
VT
You posted a link to this thread in this thread?
Norcal
The UK requires 110V tools on construction site, power comes from the mains via a site transformer that steps down 240V (harmonized as 230V) to 110V with each leg being 55V.
dogdog
It’s posting a link to this thread in this thread to a post on this thread asking the same question to the op. Nuthing long with that.
dogdog
Why uk have this odd requirements for 110v equipment
R
retireddiy
I’m not doing anything specific just trying to start tinkering again. Had a heart attack and I need to get back to something. Thanks for the replies.
PCustoms
VT
Glad you're around to tinker, but for the life of me can't figure out what you're looking to accomplish.
R
retireddiy
Before things happened I was designing a box for a variac I had picked up. It was from an old furnace. I tested it and it works great but has no protection covering the coils. Then learning about an isolation transformer it got me thinking hence the question.
PCustoms
VT
You really still haven't told us anything about what your doing.
You asked how to convert a transformer with 240v primary and 120v secondary to 120v primary.
Maybe I'm missing something with the European voltage, but I don't see what you're trying to get at the end of it.
PCustoms
VT
so He wants to build an isolation transformer . I was wondering about that & almost posted it in my previous post to ask the question.
Isn't an isolation transformer wound different?
I'd expect 60v out of I fed this with 120v...
The Cobbler
I don't know much about isolation transformers, other than their purpose. I thing the original poster should be asking that question, if that's what he is trying to build.
we are all sort of guessing here as to what he wants to do .
R
retireddiy
Thanks all it’s the first thing I grabbed out of my stuff. New toy 8 bucks I haven’t tore anything apart for awhile.
dutchgray
Dorset. England.
Whilst this is true, nowadays many construction sites in the UK disallow the use of any mains power for any construction work, you use cordless only and either charge batteries at home or in the site welfare cabins (where there is power for heating food, running a fridge etc). This has usually been mandated as the developer can save a bit on their insurance and not having to provide temporary power supplies.
It came in in the 1970's I believe, before anyone had RCD protection in the power supply and a decent 240 V shock from a metal bodied corded tool or damaged extension cable was a likely fatal and a fairly frequent event.
55 V from one leg of the 110 V isolated transformer only tingles a bit.
The wiring in industrial or construction settings back then often used to be truly shocking (pun not intended) and frankly it's a wonder more people weren't killed.
