ULine Welded Steel Workbench
quilty
Looking at finally replacing my folding table / moving blanket combo with a legitimate workbench. Mostly working on recreational light-duty automotive (motorcycles, snowmobiles, dirt bikes, etc.) So there will definitely be some oils/greases/cleaning solutions involved frequently, kind of why I like the idea of a steel top over wood. I also need to be able to solid mount my Wilton vise.
I came across this workbench on Uline's website:
All welded construction, 2" square legs, 12gauge steel top, claims to be made in the USA. For $730 bucks it seems to be a good deal. Does anybody have any experience with these Uline workbenches?
I see they also offer a 1/8" thick workbench mat that I could lay down for more sensitive projects.
Thank you
Max
Georgia
The first one looks like a very good quality industrial type bench. The second one’s legs do not look as sturdy and at $1500+ it’s kinda pricy. (Granted Grainger is generally expensive.)
Zoro carries similar type stuff, and if you get a 20% off coupon that could help a lot. Since these are welded they will ship large, and shipping cost might add a bunch.
I forgot to add that for engine/mechanical work, rubber over metal is a good option. But butcher block will need protection from gas and oil, and it scratches easily.
Q
quilty
I just found the same bench without the drawer for $1,100
Yea, I'm really torn between a steel top and butcher block top now...
vrinner
Placentia, CA
Looks like the one I got from my work and they bought everything from U-Line. You can see it's up on some wooden blocks because apparently they (this was our plant engineering group's workbench) thought it was too low and they also filled in that blank space with a piece of wood. The shelf I figured was a good idea but raising it up seemed weird because those guys were all short. Works for me though.
LXCam
There's nothing to be torn about.
GJ wisdom denotes one must own both in order to not lose man-card :spit:
U-line as well as Grainger / Zoro sell quality stuff, but you pay for it. No matter what material you decide on, I'd take the advice already given to you and get it from Zoro when that have a decent discount code. If you've never dealt with them before they are more or less a clearing house kinda deal for Grainger. Sign up for their site and put what you want in your basket and wait - you'll get a discount code within a week or so.
Q
quilty
That's great advice...thank you.
racecougar
Missouri
I have two of the benches in your first link. They've been in service here for 4 years, and I have no complaints. They are good solid units.
EDIT: I take that back. I have the lighter duty Industrial Packing Tables. Still, zero complaints, and I put them through their paces.
GirlnAgarage
Texas
We've got the Uline Welded steel machine tables 2x3ish size on casters at work and they are no joke. Everyone hates them because they will jack you up if you bang your ankle into the square foot pad but I love the construction, they are sturdy. The welded areas are not completely slag free, you'll need to take a file and knock off a few sharp beads which is a shame because they are already finished. One gripe, the paint chips easily on the top. IDK what my coworkers do but they've managed to scrape off small areas of the surface andthey're less than a year old. I don't know what it is that we can't just have nice things.
Ben Glaser
Elkhart Indiana
Fasten legs to floor, add the braces, and a Bally butcher block 2' thick with rounded edges.
CraigStu
Blacksburg, Va
Look at lowes and HD and wood flooring stores for butcher block. I have a wood top on my tool box and it is pretty good. Sure looks nice but I always worry about it getting damaged. I would prefer steel.
Q
quilty
I've narrowed it down to (3) separate models from different manufactures:
Little Giant
JAMCO
And also the original Uline model
Looks like the Little Giant has 4k capacity, while the other two have 3k capacity. The Little Giant model has 1-1/2" x 1-1/2" x 3/16" thick angle iron legs, where as the JAMCO and Uline products have 2" square legs. Not sure which would be best.
CraigStu
Blacksburg, Va
Generally I'd prefer the legs to be square but they don't give wall thickness. If they are 1/16 walls they may be weaker than the angle legs. OTOH 3/16x1.5x1.5 is a nice chunk of steel.
pl_silverado
West Bradford, PA
Having just gone thru the same ordeal trying to find a workbench, I just ordered 3 of these...7ga top vs 12ga on that uline, and slightly cheaper with free shipping to boot. If it's built anything like their cabinets, this is a steal. Wonder what condition it'll show up in beings its listed as overstock. Likely better than most of the cheap used **** on Craigslist and facebook locally.
Q
quilty
Man, too bad that's 84" long. If it was 72" long I'd be all over that.
Where'd you get the free shipping from? I added that to my cart just to see and it's charging me $134.70 for shipping.
pl_silverado
West Bradford, PA
Directly from them. I ordered two cabinets aswell, to a business address with forklift to unload so maybe thats the difference.
Q
quilty
I typed in shipping info for my business address as well. I'll double check with them.
I also just noticed that table is 36" depth as opposed to a 30" depth. Not sure if that will make grabbing things off the wall behind it a challenge. Kind of sharing the same thought on that full-depth bottom shelf. I like the idea of a half-depth bottom shelf for your feet as wll as being able to just slide things under the table.
Q
quilty
The JAMCO legs are 7 gauge steel.
rocco
Moncton N.B
I have three of those Uline benches in my shop and they are extremely sturdy the paint is terrible and flakes right off though.
CraigStu
Blacksburg, Va
7ga is .179" and 3/16 is .187" and the legs are 2" square (I think I read that correctly) so they would be significantly stronger than 3/16x1.5 angle.
rmmiller
Kennewick, WA
We have an old Uline bench at work. This thing gets abused, incoming freight and heavy parts get slammed around on it daily and it's still in good working order. It does have a slight sag but I think that's from some of the big boys we work with sitting on it.
Sumboodie
AK
There's no way a bench with a 1.5" thick steel top is only weighing 176lbs unless it's wood with a thin steel skin.
My bench has a 3/4" thick top. It's 3x8ft. It's probably over 700lbs.
