Ultrasonic cleaner and solution for bike chains?
BrooklynBravest
I’m looking to buy an ultrasonic cleaner to remove grease from bike chains.
Is it worth buying a cleaning concentrate for $35 a gallon or is there equally effective, cheaper alternatives?
danielbuck
yeah, hot water and whatever degreaser you like, ultrasonic should clean them fine. and plus1 to the smaller container suggestion.
isb cornbinder
I like everything about my ultrasonic cleaner. I have done all of the mentioned ways in the preceding posts. They all worked really well. ZIP-LOC bags are another idea to separate the dirty parts from the clean fluid. I have used solvent in the ZipLoc.
Nessism
Torrance, CA
Go buy a gallon of mineral spirits, and find a large Gatorade bottle (or similar). Fill the bottle 2/3 full with the spirits, drop the chain in, and shake like hell. Let it sit, then come back and shake again. Repeat a few times, over an hour or so, then pull the chain out and hang to dry. The spirits will turn black, but with time, the black chain sludge will settle to the bottom of the bottle, and the fluid on top will turn clear. At the next cleaning cycle, pour off the clear fluid over the sludge, into a second bottle, and use it again, and again.
This technique will be drastically more effective than a cheap china ultrasonic.
bonneyman
Desert SW
if it's a relatively new chain, just wire brush the outside crud off of it and stop there. The inner races and bearings have a special lube that solvent cleaning will remove while letting fine grit enter. Not good.
If it's an older chain soak away, dry it, then let it soak in 90W gear oil for a day. Phil Wood's Tenacious Oil is good, too.
Not cheap but good.
RichWolfson
New Jersey
I labored over that too. My 6L came today. Knobs instead of solid state and I am happy. It's large enough for what I need it for, tools and PinBall parts, and the things I put in it came out nice. I used Super Clean 1:3 BTW.
But that is just me. ///Me
Death Row Dave
Home
I use ATF in a jug . Shake it two or three days in a row . Hang the chain so it drains back into the jug . Use it over and over . I have an older Harley converted to rear belt best mod I ever did , I think .
Melancholia
I've had the best results cleaning bike chains using an ultrasonic cleaner paired with a proper solution that's safe on metal and removes grease effectively. If you're considering upgrading your setup, industrial-grade cleaners like https://www.kaijo-shibuya.com/industrial-ultrasonic-cleaners/ are worth looking into. They’re built for heavy-duty cleaning and can handle tough jobs like degreasing chains with ease.
seber
Deep East Tx.
Denatured alcohol, kerosene, stoddard solvent, mineral spirits and a lot of other cheap solvents all work well for grease and oil. I haven't tried engine degreaser, but I'd bet it would work fine.
jobo1004
Kansas City, MO
I imagine the OP has already made a purchase by now, but I'll state for the future that I've been using the 2.5L ultrasonic cleaner from Harbor Freight along with simple green to clean bike parts. The largest cogs on my cassette stick out of the top of the cleaning solution, so I have to rotate it once during cleaning. I definitely wouldn't mind having a larger cleaner, but I'd imagine the 6L unit they were pondering would've been of sufficient size for bike stuff.
GeoBruin
Simple green in the HF ultrasonic cleaner is my go-to combo as well. I keep 2 containers of simple green. One that I use for general cleaning, and another that I pour back into the container after using in the ultrasonic cleaner (through a coffee filter).
VR6ix
Onterrible, Canuckistan
Debating if i go 6L now or 10L
I don’t need anything huge but 6L sounds pretty tiny
6L is tiny, go bigger so you can fit cassettes and chainrings in one cycle, instead of having to rotate them and run them twice. I kinda regret not going bigger right away.
Any non-caustic de-greaser should be good. Use glass jars or Ziplock bags as suggested. Fill the unit with hot water from the tap instead of waiting for the on-board heater to get it up to temp.
Shiftless
East Bay SFO
I’ve heard of using the ultrasonic cleaner to clean your bike chain and also the black grease from under your fingernails and in your finger prints. I suppose that is not safe, right?
todd_fuller
The Cobbler
I would not use an ultrasonic cleaner to clean grease off bike chains.
mineral spirits, diesel fuel . something along those lines will be far more effective both cost & effectiveness than an ultrasonic cleaner
