Keep your fingers and hands out of it.
Won't hurt a thing to put either in the tank occasionally.
Thank you.
I was looking at a 10L one with 240W usonic power and 250W heating power for under $200.
A 250W heater with a 10L tank is real wimpy. Try to get at least 500 watts with that tank size or it'll take all day to get the bath to an effective cleaning temp.
+1
Biggest obstacle using a u-cleaner is waiting for it to be warm enough, I always regret running the u-cleaner when its still warming up because I'm impatient.
I know you have a budget but something to think about, especially living so far north (burrr).
I waited - the first time. The next time, I dumped hot water in it and used the heater to keep temp.
I wondered the same... just boil water in a kettle and dump it in the tank.
except it's very uncomfortable. It can cause skin or joint problems if you leave it in too long or do it every day.Won't hurt a thing to put either in the tank occasionally.
Did you buy it on Ali or somewhere else? Can you list the make/model?
+1
Yes if you want boiling water, there would be extra steps and wait times. My ultrasonic heating temp range is 68° to 180°, so anything above 180° is not possible from the internal heating element.Both quotes just reinforced what I said. Whats the difference in time between the two? Aside from the added hassle dealing with hot pots of hot water, its extra steps, just turn on the U-cleaner heater and go post on GJ or something while getting rid of your coffee, it will be well ready when your done. Besides, heating up tap water is not the best way to go for u-cleaning but it can be done, distilled water is way better for your toasty warm item, it's mega cheap and less hassles to deal with your item that hard water on it after pulling the item out, for example; personally I would avoid using tap water to clean your injectors or carbs.
I found this one: https://www.ebay.com/itm/123956572790
But shipping to Canada is US$130! Ha!
In Canada, there's one with knob controls, but only 400W heating for a 15L tank. I cannot find much else.![]()
My hot tap water comes out at 130° which is plenty hot for starting ultrasonic cleaning. My hot tap water offsets any wait time of waiting to heat up cold water with the heating element.
Thank you!This guy is on the West Coast and he ships anywhere. I have purchased two ultrasonic units from him, Good service and knowledgeable.
https://vancouver.craigslist.org/rds/tls/d/65-ultrasonic-cleaner-with-timer-heater/7265840784.html
Okay, you mean you dilute your bath every time you want to heat up the Ultrasonic cleaner by adding more hot tap water to it? How many times do you do that before changing out the bath or do you empty it out after each use or just your ok with making a weaker bath as you go?
So, it's decision time:
10L with 400W heater (240W Usonic)
Or
30L with 800W heater (600W Usonic)
Now, is bigger always better?
I just wonder if I would be wasting a lot of fluid and energy for small stuff.
I do have an old engine on a stand that I will be rebuilding. And the intake valve cover and oil pan would fit inside the 30L unit! I guess I could even clean the engine block if I turn it and clean it in sections, but perhaps the middle couldn't be submerged even if the ends can be.
Besides that, I would be cleaning the carburetor and other small bits from it.
I also have a BMW VANOS unit that would be a candidate for cleaning.
Then I would clean only rarely as I disassemble some suspension parts like wheel hubs and maybe brake calipers.
So, I'm really debating between these two options.
Thank you. That's another good option.prior to my ultrasonic, if I needed hot water for cleaning, I used somethng like this:
bucket heater (link)
You can use a simple 120v timer with it to turn it off at a certain point.
I wonder if I can use one of these to heat up the solution and they remove it and whether the measly 500w heater would maintain the bath temp reasonably high for rhe 20-30 min cycle.
30L would be overkill size for me most of the time, so I plan to store it filled with distilled water pretty much always (to avoid dumping out 30L every time) and sumberge small things in glass containers as needed.
Ah, yes, good point.I'm sure it would. Don't forget that ultrasonic action also produces heat.
What's a minimum amount fluid to run in these? Would half fill be sufficient without damaging anything?
My 10L tank will heat up with use, with the heater turned off. As I mentioned before, I use it for cleaning LPs so I would like it to maintain a warm but not hot temp; a long session will get it hot enough I'll quit for the day to avoid warpage.
Rather than using glass jars, ZipLoc bags work better. You can use the cleaning agent or solvent inside the bag and leave the water clear.
Like the Ronco Showtime Rotisserie commercial said, " Set it and forget it." Easy stuff.
No, plastic absorbs/attenuates ultrasonic energy. Glass is a much more effective secondary container.
My 30L is inbound!
Thanks for answering my dumb questions so far, more dumb questions to follow as I start learning hands-on.
A used Dareflow brand.Which 30L unit did you end up ordering?
That makes sense to me as well that rigid material transmits vibration better.No, plastic absorbs/attenuates ultrasonic energy. Glass is a much more effective secondary container.
I vote for Simple Green Extreme Aircraft. It's totally aluminum safe and very well regarded in the aviation world. I really like it.
Not nearly as expensive as pro solutions that can be $60-150+ per gallon (11 liters) like Branson GP solution in Canada and others.
I would be very leery using Awesome as a solution for aluminum in a U-cleaner, its very cheap but caustic to breathe especially when heated and can eat aluminum. Fine for surface cleaning but then I found others that work just as well.
