Ultrasonic Cleaners
moparfreak
Milwaukee, WI
I'm thinking of getting an ultrasonic cleaner for cleaning small items, nuts and bolts off the charger, wife's jewelry, etc.
Has anyone used this one from HF?
https://www.harborfreight.com/25-liter-ultrasonic-cleaner-63256.html
I used to have a smaller version from HF that worked decent, except it got cracked during a garage move.
What are the best cleaner / degreaser solutions that folks have success with?
dodge610
North Canton Ohio
Yes I have that exact one is sitting in my garage. I use it for the same purpose and and use it with simple green. For degreasing works fantastic. Used the cleaning powder i allready had to clean other things. Havent tried HF cleaning powder.
moparfreak
Milwaukee, WI
I figure the best way to restore hardware is run it through a vibratory tumbler first to knock off the corrosion and scale, then use the ultrasonic to get the grease. Does this make sense? I've got a LOT of hardware coming off the charger I can't replace so I'd like to restore wherever possible. Is there any step missing?
bluebolt
Benton LA
I would use the ultrasonic first to get rid of the grease so it doesn't contaminate the tumbler media.
M6erfan
'Merica!
I also have that HF USC for the same purpose. What I do is soak the parts in a degreaser to clean as much grime as possible (I use everything from Superclean, Kerosene, WD40, depending on the situation) then put the parts in the ultrasonic (usually in a container of kerosene) to give them a good deep clean.
I've had mine for about 4 years and it's held up just fine. Use it for lots of small parts, fasteners, carburetors, jets, etc.
I don't use a media tumbler but that seems like a good idea
dodge610
North Canton Ohio
Yes sir i use the vibratory tumblr second also got that at HF it was the biggest benchtop unit they had. So far zero complaints on that also its held up very well. Use media i bought at menards in that.
Cahark
Dayton,Oh
I use the simple green aircraft Precision cleaner in my ultrasonic. It’s an absolute workhorse for most of the jobs that I do.
It takes about six Ounces per gallon of water. Also, it works much better at high temperatures than low temperatures.
ndnchf
Fredericksburg, Virginia
I have the same one. It works well with a 50/50 solution of simple green and water. One tip, seal the joint at the top of the metal tub to prevent liquid from getting down into the electronics. I used RTV silicine.
dodge610
North Canton Ohio
Thanks for the tip never thought about it till you mentioned it going out to do it now while its empty and dry.
moparfreak
Milwaukee, WI
Does that simple green aircraft cleaner work really well? I'll definitely have to try that one out. That small one was alright but I would like the heated element as well as larger capacity, plus they don't sell the small one anymore.
mikebaker1129
Huffman,TX
I just microwave my bowl of ware for 5 minutes ,add to the US cleaner,add chemical and turn on.
I use a chemical available in our storeroom called Hurricane.
Hot water makes a huge difference !
gtr1999
CT
Those little bench top US cleaners are limited but may work for your application. I use commercial US cleaners we had made and have provisions for heat and filtration.
Since our production has been send outside the USA now I had couple of 6' US benches I couldn't give away. If I had room I would have taken them.
US come in various frequencies, average is 40 kHz. More aggressive would be 30 kHz, higher Frequencies will be finer implosions.
Simple green will work 50-50 but it will work better with hot water. Some of the better Branson little benchtops ($1000) come with heat and timers but I don't recall any with filtration.
Important with these tanks is to never start them dry or very low you will burn out the transducers on the bottom of the tank in no time. Since these are Chinese made they probably are no where the quality level of the USA ones so I would expect the performance among them will vary. Be careful not to stack parts too tight either as the sound waves may be blocked. Use SS or glass to hold parts, plastic will block the waves.
ndnchf
I use mine (50/50 simple green/water) to clean antique sewing machine parts of 100+ years of dried oil gunk. Here is an example of before and after 15 minutes in the hot tub. What little still remained was soft and easily removed.
guy48065
Calibration Lab
Is the HF (larger) unit powerful enough to excite the solution in a smaller container set in the USC bath?
I've heard it's a way to clean with different chemicals without ever changing the regular bath--but to my eyes the action inside the cup is noticeably less than outside.
I could be doing it wrong...
ndnchf
I often use a pickle jar with solution in it to clean tiny screws and other bits that are more easily lost in the main tank. I fill the jar with hot solution from the main tank, put the parts in and set it back in the tank. When done I can lift it out and use a magnet tool to pull out all the little bits, nice and clean.
tool-guy
victoria, australia
We are in the process of having 1 built that will be 4 feet wide, 3 feet in length and 3 feet deep with an overhead gantry and rotator to allow wheels and rims to be cleaned. Not cheap but will be a huge time saver for cleaning wire wheels and without the harsh chemicals for the cleaning of wheels of the high end cars.
Zewnten
Had several of the HF ones at work, get the warranty IMO, ours only last about a year ish with fairly heavy use. And we use a splash of simple green with hot tap water.
M35A2
Coos Bay, Oregon
I got one mainly for cleaning old cycle carbs but now I a using it a lot for gun parts too. I got a bigger one off amazon and it is great so far. For really oily/greasy parts I have found Blue Dawn soap and water works really well and cheap. For carbs, Ultra simple green for aluminum works awesome.
