LoLMine runs at approximately 19 kHz. This is noisy and can drive us and the dogs crazy. It works like a charm. Newer units tend to be above 22kHz. We don’t hear it but the sure do!
You do have to fill the ultrasonic cleaner with water, but yes then you can put another container inside it containing your cleaning solution of choice. I know people who just use a cheap plastic cup or container, but I suppose you have to be careful doing that if you use the heating function.So if I have a smaller item I want to run through the cleaner......I can put it inside a Pyrex beaker in the basket and just fill up the beaker ?
I am guessing it has to be suspended as well? Like in the basket or hanging?You do have to fill the ultrasonic cleaner with water, but yes then you can put another container inside it containing your cleaning solution of choice. I know people who just use a cheap plastic cup or container, but I suppose you have to be careful doing that if you use the heating function.
I suspect only because the stainless steel tubs on these inexpensive imports are pretty thin, and subject to damage if not used with some sort of hanging basket.I am guessing it has to be suspended as well? Like in the basket or hanging?
Back when I worked for a manufacturer, I spec's out some nice custom-made ultrasonic machines made by Bluewave in Davenport IA. I have since left that job after 30 years and have my own shop. The systems we had made were 30 khz Magno restrictive transducers that would last a very long time. Most are bonded to the tanks and don't last more than a couple of years before cavitation erosion blows a hole in the tank or the transducer fail.
These little Chinese tanks are knockoffs of Brandson Sonic table tops and not as good. For a limited use they may work, the power levels I am not sure of, maybe 40 khz? You need heat and a soap that will degas fast. Water has air in it, if you add soap that won't degas or bleed out, it will impair the action of the tank. If you run them low on water or dry, they will burn out. SS containers or glass work well, plastic blocks the waves.
A quick test of the action of your tank is to use a piece of aluminum foil in the water for 30 sec, then a minute and compare the pin holes in it from the implosions. Are they large or small, spaced apart or close?
When the company I worked for sold out to the French they started to cut people and jobs since they only care about profit and using the cheapest labor they can find worldwide. The machine shop was removed, those machines were sold for next to nothing and I maintained like new. $40k to build, sold for under $1000. I wish I had the room to buy one. They were set up for oil removal, oil skimming, and only needed pm filter changes every 2-3 months when used every day for 8 hours.
The foil test is a standard test of transducers efficiency and power. If, by chance you notice a decrease in cleaning ability. You would run this test and locate areas of weak or no transducer operation. There is the ultrasonic generator electronics and the transducer plate, both need to work. If I recall, there was a pencil test that could be done for efficiency.Great info.
I wanted to clarify - these are safe to use on aluminum parts, including critical ones (i.e. something that seals - cylinder head, oil cooler, etc.)? I've read that the answer is yes and as long as an Al safe solution is used. However, I am a bit weary, particularly in the example you listed above of putting tiny holes into the aluminum foil. I don't want that (microscopically) happening to a mating surface and causing problems. I don't know enough about it, but perhaps you can shed some light?
I am going to remove the valve today and try to match up the threads for a hose barb fitting and small section of tubing, for the drain
The company can't figure out the threads
For the manufacturer who most likely sits somewhere in the metric world that is close enough to 1/2”.It's marked 1/2" so I'm hopeful true value will have a hose barb for this and it's a standard thread
The manufacturer could only tell me 12MM.......wtf does that mean
Ah I see. Not sure if you or @gtr1999 can answer, but for a lay-man like me, I guess it comes down to: does the holes in aluminum foil = pitting on cast aluminum parts? I tried do a bit more reading about the frequencies 'safe' for Al, but am getting conflicting information. Although so many people use/swear by them for engine parts, I want to be super sure before trying to clean hard to find or discontinued parts.The foil test is a standard test of transducers efficiency and power. If, by chance you notice a decrease in cleaning ability. You would run this test and locate areas of weak or no transducer operation. There is the ultrasonic generator electronics and the transducer plate, both need to work. If I recall, there was a pencil test that could be done for efficiency.
Does the ultrasonic cleaner do a better job at removing that residual black/gray coating that's left on parts after they've been in Evaporust for a while?I used to buy lots of hand tools on Craigslist. I like to freshen the tools up before I put them away. I bought and use an ultrasonic parts cleaner. The unit I have is a 30 liter model. I would say heat is important and having a strong ultrasonic action is also important. The wire basket is an important part of the cleaning.
EVAPORUST works many times faster in an ultrasonic cleaner. Hours of waiting time can be reduced to minutes. I bought my unit of a Craigslist seller. This guy is a regular CL advertiser and he has lots in stock. He offers a good warranty. This is my second unit from him. My friend bought my first ultrasonic from me. I up-graded to larger and more powerful.
6.5 L Ultrasonic Cleaner with Timer & Heater Stainless - tools - by...
New DURASONIX Brand 6.5 Litre Ultrasonic Cleaner <<<<< This attractive robust device, comes with Stainless Steel Basket, is a commercial grade, built totally with stainless steel....vancouver.craigslist.org
I can not say. I use Evaporust in my ultrasonic and it works many times faster. There is the possibility your pieces may have been left in the Evaporust too long.Does the ultrasonic cleaner do a better job at removing that residual black/gray coating that's left on parts after they've been in Evaporust for a while?
Glass is Ridgid and restricts ultrasonic action. a plastic bag is compliant and the ultrasonic action transfers easier. Do what you think is best for you. Try to not cut yourself.I have hours of ultrasonic cleaning in jars with zero issues.
Plastic absorbs the ultrasonic vibrations, that's why people use glass to begin with.
