Ultrasonic Solution to Clean Door Hardware
tperk100
Virginia Beach, Va
Doing front entry facelift. Was going to just replace 15 yr old tarnished (antique brass?) latch and deadbolt set but occurred to me that I might be able to clean it in my ultrasonic. Anyone know of a DIY solution that might work?
Thanks
Jswain
Calgary, AB
Citric acid. A very small amount. Start with a quarter teaspoon in some warm water and keep an eye on it. If you use too much it can turn a pinkish color
dogdog
I just use NEVR-DULL on brass cleanups... .if you have a buffer, would make the job heck lot easier but otherwise, elbow grease. It can bring out some 50+ year old dull brass mail box to shinny and bright.
There is also brasso, but I don't think it is as effective as the NEVR-DULL.
T
tperk100
Virginia Beach, Va
Started out with Brasso, Dremel, Elbow, Buffer.... Gave up. Don't have patience for Knocker, Deadbolt, and Latch set. Am trying to clean with Citric now.
dogdog
would be interested in the results. post some pics.
pwhittle
Woodstock, GA
We just had our front door hardware powdercoated.
It was much cheaper and faster that replacing it.
Paul
Sent from my iPad using The Garage Journal mobile app
T
tperk100
Virginia Beach, Va
Don't have before pic. Take my word for it. This knocker was black. But let me splain how my **** self went about this.
First tried mostly water with drop of Dawn and tbsp of bleach. No help.
Next tried citric as suggested above. Knocker turning orange but not brassy looking. Added more Citric. Now turning Real orange.
Next tried internet recipe for cleaning brass ammo cases. 3 Qts Water, 3 Cups Vinegar, 3 Tbsp Salt, 3 Tbsp Dawn. No change.
Through all this I ran my U/S for 30 minutes at 140 degrees about 6 times
At this point I'm ready to trash the knocker which was the original plan since this grumpy old man don't want nobody to come a knocking anyway.
BUT...something made me try the Brasso again. Amazingly I only needed to apply, let it sit for a few minutes, and rub lightly with a toothbrush. it worked like a charm.
This knocker is real brass. I don't know what I am in for with the latch set.
gungatim
west mich
I find the problem with the high end brass door hardware is that it is clear coated, which eventually disintegrates. that makes the polishing take forever. you can clean the clear coat off with chemical stripper but it will be like polished aluminum rims.
you'll need to constantly polish every month unless you clear coat it again.
T
tperk100
Virginia Beach, Va
Funny you should say. I plan on coating it with something, but don't know what yet. Any suggestions?
gungatim
west mich
clear epoxy works, you can get it in a spray can with the hardener in the bottom. pierce the can and mix. it isn't cheap though. I bought some but never got the finish I wanted and never used it.
I gave up and just bought a new set. could have saved $60 if I just replaced it to begin with, lol...
Dumber than lumber
Krylon makes clear sprays. Satin, gloss clear, ... they say it is “triple thick”.
Easy to use. Dries fast. Go with a few THIN coats to prevent runs.
Jswain
Calgary, AB
Try less heat and half the amount of citric for the next batch and it should help it from turning orange/pink
