Above 1200 Sq/FT Uncle HoHo's Big Mountain Playstation
H
hoho98925
East of Seattle
Re: new construction (yet unnamed)
This is what 10k gets you.
Craigslist Score- came out of a School in Western Wa. The demo guy even delivered, They are oversized, I will plane the faces that are exposed, saved serious money over new. $$$$$$
Sill plates going down.
String lining at cutting every stud to get a perfect top plate.
Mezzanine wall framing.
H
hoho98925
East of Seattle
Cutting back the existing roof so it aligns with the shop wall. You like my temp shoring?;)
Roof cut back sliding truss back into place.
Framed this beast flat with the sill plate on the concrete, the horizontal 2x supported the wall while built, squared and sheeted, it was a ****** to stand up, put in place with the excavator.
Just like that
Placing the beams with some heavy equipment.
These are big beams.
The 2x is a ledger the trusses bear on.
Working our way out.
All Beams set!
H
hoho98925
East of Seattle
I love the openness of these floor trusses, it's going to be so easy to run MEP's through them!
H
hoho98925
East of Seattle
More of the Flooring system.
Throwing down the floor. From these photos it appears Zack is the only one working....haha i assure you i was right there as well. there was mostly just the two of us framing this, somebody need to take the photos.
The neighbor showing up (y)to "help"
Walls going up, I framed through the headers, not sure what size windows will go in yet, probably whatever is left over from one of my work projects.
H
hoho98925
East of Seattle
3/4" T&G glued and nailed with Ring shanks, nice solid floor system.
Time for some wall action.
H
hoho98925
East of Seattle
Our afternoon break, a little hike up to Silver Creek. It's about 2 miles from the house.
Starting to take shape.
H
hoho98925
East of Seattle
Afternoon ride to the lake for a swim.
H
hoho98925
East of Seattle
Truss time! no help this day. This was exciting to try and get these secured by myself, other than the truck driver.
These trusses are designed to 154# snow load, they are heavy.
Just over $12k for this delivery.
Scissor trusses for the future living room and hang out 6' for the covered porch.
a couple of toenails in the heels to the wall, a brace on each side then shimmey up the bundle to unhook the chains.
Attic in the truss.
Strategically setting the trusses to make it easier to roll later.
ADSR
holy ****! That's a lot of concrete! You guys button up and get it done fast!
Nice work!
H
hoho98925
East of Seattle
Nice work!
Thanks guys! It was all me untill Thursday at 1pm, that's when my buddies showed up. We kicked this walls **** for sure. Poured it Friday at 11 am. Thank goodness for friends, by 2 on Friday I was treating them to lunch and drinks at the local Cantina :beer:
ADSR
How the hell did you get all ties in the holes and hold the sheet as well? Youre an animal!:beer:
Its damn hard with two people and a stick with a nail in it!
MagKarl
Olympia, WA
The scale of this project is awesome. Looking forward to seeing the building take shape. Well done.
H
hoho98925
East of Seattle
Flying...
Spreading the bundles out to try and be efficient.
Rolling, rolling, rolling
H
hoho98925
East of Seattle
And more truss photos. We used some scaffold and planks to be able to work the trusses into place.
you can see the overhngs for the covered porch across the front.
Break at the lake.
The 2x on top the trusses on both sides allowed two of us to keep these heavy things vertical while we moved them.
This 2x goes from the trusses already installed to the bundles of trusses, we would peel off one truss and slide it into place,,,,,ez peasy.
H
hoho98925
East of Seattle
All the braces plumbing and lining the walls, installed before trusses installed.
H
hoho98925
East of Seattle
Some exterior shots from the street side.
H
hoho98925
East of Seattle
This is exhausting.
Sheeting the gable before standing it up. Its along ways off the ground.
Needed to bring in some more help to lift the gable end truss and the scissor trusses, they are top heavy and wobbly.
PERFORMANCE-RED
Wow that was a lot of concrete! can't wait to see the one come together.
H
hoho98925
East of Seattle
Gable end wall from the driveway.
Lower garage door shear walls Framed and nailed off.
H
hoho98925
East of Seattle
Tails laid out for cutting.
Tails trimmed, sub barge and fascia being installed.
ADSR
Thats a big *** beam!
H
hoho98925
East of Seattle
Sheeting Roof 5/8" plywood. Clips at areas with trusses greater than 16" oc
ADSR
Smart to scab that 2x4 to the beam to sit the trusses on. By code can you leave it on, or do you have to install hangers?
H
hoho98925
East of Seattle
These trusses are designed to set on a 2x. I gave the truss sheets to my engineer, and he gave me a detail for the connection with 12d staggered on 3" centers. So no hangers. That saved a pile of money for sure.
ADSR
Well done using the recycled beams and trusses! You're saving money left, right and center doing it that way. Great planning ahead!
