48divco
Hello I have been on the Hamb for years. Bob, divco13 on the Hamb
http://www.garagejournal.com/forum/member.php?u=120663
Any thoughts on this style unit's ?
Frist unit on the left.
Evaporator assembly- 32,220 btu
36 pass 4 way alum coil
610 CFM
32,220 BTU
12 Volts
Left hand drive
O-Ring expansion valve
R134a or R12 compatible
33in x 14in x 7in
Mounting brackets included
Drain hose included
Unit on the right.
4 SPEED
390CFM
12 VOLTS
Elec. Thermostat
Remote control fan spd. and thermostat
22 pass 4 way all Aluminum coil
expansion valve
2 double shaft blower motors
high impact plastic case and louvers
mounting bracket drain hose and T included
610 CFM
32,220 BTU
12 Volts
Left hand drive
33in x 14in x 7in
Drain hose included
Unit on the right.
4 SPEED
390CFM
12 VOLTS
Elec. Thermostat
expansion valve
