Under lift transmission jack
GBguy
I've researched this on my own for a while but could use GJ member input as I now have my lift installed and want to get on with projects.
I'd like to use a transmission jack for:
1) transmission R&R
2) rear/front axle R&R, and even
3) hoisting my 35 year old oil drain pan.
I want 2-stage so I can easily transfer the transmissions to my stainless workbench or the axles to my differential fixtures.
I want one that you can lower via foot control rather than bending down to release pressure.
It would be nice to have one that pivots on 2 axes, but doubt I can afford this so it's secondary.
My budget doesn't allow for a $1000+ jack, but I don't expect these features in a $200 unit either. And I've watched classifieds and auctions for MONTHS without seeing anything except what others bought and don't like.
Is there a feature I should want that I haven't already mentioned?
Does anyone have recommendations for 2-stage brands/models with foot pressure release in the $400 or $500 price range?
Is there a particular vendor you'd recommend?
jchen82
E. Palo Alto
I have one look like fit your requirement. It was made in Detroit and lifting capacity 10000 lbs. It is very heavy probably weigh over 200 lbs. I am in Bay area of CA.
toplessHO
central florida
I bought a used one off Craigs list many years ago and it works great.
other uses include but not limited to
control arm and strut replacement
fuel tank R&R(this is real nice if you just filled up and the pump quit)
G
GBguy
Thanks for the replies and especially your suggestion parks31.
I had found that model at a specific vendor - who prices it above my budget ($889+!) but hadn't thought to look for other retailers via the sunextools site (duh!). Summit and Jegs (among others) list it at $590ish. I'll call retailers close by me as suggested by sunex to see whether they sell directly and allow pickup. Thanks again!
ephotrod
Texas
Gray manufacturing makes the best transmission lifts. Used in an auto salvage for 7 years not a single hiccup even when treated rough.
G
GBguy
Don't doubt that Josh, but their under lift model is WELL outside my price range.
