Mungo Park
From my reading here about insulating the cement pad you put the vapor barrier down then the insulation down, then the rebar then finally the cement. Is this right so far?
Also do you run the insulation right out until it touches the onside of the cement form?
I live in winnipeg (read the frozen north) so a frost shield is near impossible.
Once the cement is cured, the forums are removed do i put more insulation around the pad, outside, sort of like the forum was?
A company is putting up the garage and I am adding in the insulation.
Cheers Ron.
Cheers Ron.
Im new and need good teachers Thanks
