Hi everyone, I've just found this site and have enjoyed mining it for information.
For many reasons, I want to build my new garage underground. This will be in north Arkansas, rocky soil, and built into the side of a hill. I want a nice size shop, maybe about 50' X 100'.
I am thinking of digging out the side of the hill (or slope) with my backhoe and bulldozer, then erecting a conventional steel building frame with purlins and girts on a conventional slab, deeper where the 2 post lift will be. Large gravel under the slab and french drains along the walls will be used to help drain water away from the building.
Notice I said erect the FRAME for the steel building. I am thinking of covering the frame of the roof and walls with Ferro-cement to serve as waterproofing. (There will be no sheetmetal on the walls or roof.) You may need to go look up Ferro-cement. I had to. It has been used for hundreds of years to make water storage tanks and Boats.
According to this website, http://www.ferroboats.com/ ferro-cement boats built before 1855 are still in existence and at least one is still afloat.
Ferro-cement should serve as waterproofing. Even though Ferro-cement has been used to contain or seal against water for hundreds of years, surface bonding cement could be used over the ferro-cement as an excellent insurance aganst water penetration. The next thing is roof and wall loading. This website http://steelbuilding.com/ is Very Good. Go to 'price building' and you will see that they can supply you with buildings designed to accept 56 inches of snow load for the State of Maine. This is comparable to the approximately 3 feet of dry earth (or its equivalent) that will be needed to cover the roof. Wet dirt is a LOT heavier.
Expanded polystyrene is readily available in sheets and blocks of any size. This can be placed around the walls before the dirt is backfilled and dramatically lessens sidewall loading and of course can be used to cover the roof too. It is obvious that the EPS will serve as insulation.
There are also membranes and shrinkwrap to form a waterproof cover for the entire building.
Fresh air intake is important to minimize the possibility of moisture buildup. This site, http://mb-soft.com/solar/saving.html does not mention fresh air intake, but it is easy to see that one or more of the tubes can be open to outside air.
Sunpipes and skylights http://www.sunpipe.com/30.htm can allow light into the workspace. The ground temperature is about 58 degrees year-round. The skylites can also allow some heat from the sun, which will be welcome to bring the temperature to a more comfortable level.
There are a hundred other details, such as escape hatches on the wall opposite the doors, but what do you think of this as a start? I am very concerned about moisture leaking into the building. The ferro-cement should bond to the slab and be OK but that is my biggest concern.
I welcome any comments, good or bad. Thanks Bruce
