malibuquest
- Joined
- Feb 2, 2011
- Messages
- 16
I love the idea.. I thought about it before. I use to deliver to a company that made large concrete castings. The castings were for floors that were used in motels and buildings..
My thought was to build a "cellar" or foundation and use these concrete flat sections for the ceiling... Rubber liner to waterproof and "Dow" board to insulate. Have the side walls made with poured concrete not block so it would not have the weeping problem.
The outside walls would be coated in tar and a rubber membrane installed. The same could be used for the floor...
The weak spots would be any joints, but with the evolvement in plastics i'm sure there is a product on the market that could be buried for a hundred years without breaking down.
For access to the "bat cave" there is a lift that is advertised as --now you see it--now you don't... Alift that allows you to lower a car and then park one on top in a single garage.. Just use that lift to lower a car or what ever to the lower level..
Another plus is that it could be used as a bomb shelter... Hmmmm " Omega Man.........................
Exactly. HEre is a link to ICF type flooring/ roofing forms http://insul-deck.org/ . Even easier to get into place to pour etc. Lots of waterproofing products, spray on and wraps too.
