shamrock12
As of now, we have a large propane tank with a copper line running underground to the house. The detached shop will be using propane as the fuel source for heating as well. I've already installed an 2" sch. 80 conduit sleeve inside the pole barn with a sweep elbow below it (concrete floor will be poured soon). This sleeve also extends several feet outside (underground) as well. This should allow us to pull a line, I'm guessing yellow poly, easier than to drill some holes later. Since it would be only about 50 feet run from the shop to the house where the gas regulator is mounted, I am thinking about continuing to run the sleeve all the way toward the house to make the installation easier for everyone. 15 feet or so has already been dug up at depth of two feet.
So my question here is ... what is the code for minimum burial depth of an underground propane line? Direct burial depth? In-conduit burial depth? Does it matter if the gas line is protected inside a conduit?
Also, is this an acceptable practice to run a conduit sleeve for the entire run? Thanks!
