Underlayment under tiles? Seeking advice
kram71
Home
My friend was telling me to go with epoxy because tiles are too noisy but I like the thought of tiles.
Did you put anything under your tiles for noise?
If so what do you recommend and where did you buy it?
Will it get soggy from liquids?
Edit: Also how thick should it be?
CJDave
Fairfield, Ohio
I have 500 sf of RaceDeck Free Flow and after 5 years I still have no regrets. I used NO underlayment and there was a slight clicking noise at first but after some time that stopped. Seems like the tiles took a set to the slight contour variations of the concrete floor. Maybe after the cars rolling across the floor? I live in sw Ohio and the rain, snow, ice, slush, grit and whatever else her daily driver drags in just goes thru the slots and oozes under the tiles to the overhead door opening. This style tile allows me to wash my classic Mustang in the shade of the garage. The tiles are easily cleaned. I'm curious if the smoothness of the concrete dictates the amount of clicking. Good luck. CJDave.
K
kram71
Home
Thanks Dave. I have been doing some searches on this board. Some folks say they did not need any underlayment. Others regretted not using it. If I can buy some for $50 or less I think it will be worth it but I'd like to find out what kind to buy for sure.
Garage Flooring
Grand Junction, CO
Open tiles such as free flow. NO
Solid tiles: I used landscape fabric -- weed barrier
66HertzClone
Long Valley, NJ
I installed the RaceDeck coin top in my garage, I used this product under the tiles. In my previous garage I didn't use the cloth and was sorry I had not.
K
kram71
Home
Thank you so much for posting the product. I have seen many people speak of it but very few links to the actual choices.
RaceDeck1
Salt Lake City , Utah
...most people do not put anything under RaceDeck solid topped garage flooring, but if you do... We recommend a thin synthetic landscape type material that allows the sub floor to breath
K
kram71
Home
Thank you but thin is a relative term that is why I was looking for either a specific product or a thickness. :)
66HertzClone
Long Valley, NJ
66HertzClone, why were you sorry for not using the cloth in your first install? CJDave.
It was noisy, a definite clomp like noise with each footstep. It was annoying, it may have been because the concrete did not have a super smooth service, which allowed some air space across the underside of the tiles.
CJDave
Fairfield, Ohio
66HertzClone, as I said above, mine did have a slight noise at first but with time and wear that disappeared. Guess I was just lucky. Your floor looks great. CJDave.
yeldogt
Why did you mix tile types -- are not some open? I keep going back and forth on what I want to do in my garage.
CJDave
Fairfield, Ohio
The tiles come in solid and open types allowing for tailoring the floors to fit your needs. RaceDecks tiles all interlock with each other so you can use solid and open tiles within the same floor. I chose to use all Free Flow tiles in my garage. CJDave.
66HertzClone
Long Valley, NJ
Take a look at the photo of my floor, I put the Free Flow tiles where the tires of my daily driver rest when the car is parked. Then one days like this when I return home with snow on the wheels and packed in the wheel wells the melting snow drips into those tiles. I have a 2 foot wide by 3 foot long area for the tires.
yeldogt
I see -- and you have the fabric under that area .... I assume the water just evaporates eventually?
That's always been my concern w/ tiles .... you can hose things out the same as concrete.
SteveCh
I have a mixture of solid and Freeflow RD in my garage and workshop. Never a bit of "clacking" or noise. No underlayment, just tile atop bare concrete.
66HertzClone
Long Valley, NJ
Yes I left the fabric in place, my thoughts were that it would help with getting any liquids to evaporate quicker as it would be less likely to migrate under the adjacent tiles. They are easy to pop out, so if/when it gets looking sloppy I can do that.
nealric
I installed some landscaping fabric from Home Depot. A pretty easy step, and the tiles are silent despite some unevenness in the concrete.
K
kram71
Home
That is good. I figure it might even help if a tiny drop of oil gets through the tile. Care to give us a link to what you used?
Dan in Pasadena
Pasadena, CA
I JUST installed my True Lock HD free flow tiles (same thing/manufacturer as Race Deck) yesterday and put nothing down before placing them. Doesn't make a sound.
In SoCal there is no snow, barely any rain and even if there is my '55 Chevy truck isn't going out in it so drips aren't a consideration. I specifically did it to avoid the noise others have complained about.
K
kram71
Home
With the good barrier I bought from Amazon under my solid tile I barely notice any noise. In fact if I hear anything out of norm that you would hear anywhere it is unusual.
