Underway on New Garage
Tsunami
KY
Well, we are well underway on getting the new home and garage built. We got a good long break for in the weather. House is framed, under roof with shingles going on as I type this in. The new garage is a 36X60 with 1 -14X12 door, 2 -10X8's and a service door in between them. The foundation was poured about a month ago with provisions for water and a center drain in the center bay with about a 12 radius to have the water fall to center. Will post additional photos was progress occurs. Still stressing over lighting, electrical outlets, window placement, and storage.
T
Tsunami
KY
Foundation complete and gravel back-fill with center bay drain and water line installed. More to follow
T
Tsunami
KY
Floor poured, almost 6 inch thick. Garage door opening are sloped outward so water will not run into garage. There will be a a 10 foot over hang on front of garage with a 20 foot apron to park on. Apron will be poured later.
T
Tsunami
KY
Sorry for the sideways photo. Fresh wet cement.
T
Tsunami
KY
Load of lumber to get started on framing.
T
Tsunami
KY
Let the framing begin. Got a break from the weather and framing moved quick. Still have to make the color selection.
T
Tsunami
KY
Framing continues and trusses arrive. Trusses are 46 foot long. Took a couple hours to get them set in place.
T
Tsunami
KY
Roof and siding material setting on truck in front of barn and install should start tomorrow. Added a couple shots of the loft storage and view from the outside end view. Windows are framed and installed.
T
Tsunami
KY
Waiting for the metal install, inside will be white on ceiling and walls. Outside two-tone, sandstone on sides and taupe on roof and trim.
T
Tsunami
KY
Sorry for the long delay, it's done, work and wet weather have gotten in the way, I have started to move stuff in. Should have my cabinets installed in about a month. More photos at follow.
T
Tsunami
KY
Interior is almost complete. Got ceiling fans installed.
T
Tsunami
KY
All the lights, 20 of them, installed.
T
Tsunami
KY
Lift Master door openers. Display time and temperature, They also have the motion sensor to turn on door opener lights when I walk in.
T
Tsunami
KY
View from other end of the Barn.
T
Tsunami
KY
Got the Boss testing the floor drain, while getting the Audi clean. Two birds with one stone.
T
Tsunami
KY
Well, got all but the two other vehicles in. I'll have to put a 4-post lift in the far corner for the 40 Ford, not here yet, and put the 54 Chevy P-up under it.
