Unfamiliar tap and die markings.
Hal
Vermont
IMG_4311.jpegGot these in an old tap and die set
H
Hal
Vermont
Got these in an old tap and die set. The dies are similarly marked.
What is the significance of the second dimension! IE. 1/32
The tap has a radical taper, but that may be a regrind.
Stubby1743
UK
I've never seen a tap marked like that but could the 1/32 be the thread pitch?
RoninB4
Under My House
-There are over-sized taps. They're used to compensate for coatings, hardening of material, chrome/zinc applications, etc. They're designated with GH numbers from 1-7 in specific intervals of basic size + the oversized amount. The largest I've worked with is GH-7, which is .003-.0035 above basic size. There are supposed to be specially made taps that go above GH-7 but I've never heard of one that's 1/32 larger than basic size. Is it possible? I suppose so as there's always been a market for special taps and thread forms but it's an application I've never run into and question why a coating would need to be that thick.
-Check the thread pitch (threads per inch) to see if it's even a standard for that diameter.
H
Hal
Vermont
I suspected they were oversized they are all standard pitch for the sizes. What puzzles me is that a general repair shop would have a complete set of oversizes. They were in a wooden box, with a die stock, but no tap handle.
Also in the box, completely unrelated, were a set of Budd wheel wrenches, and a badly abused 3/4 drive slide handle.
RoninB4
Under My House
1/32 would be 32 threads per inch. Marking says 5/8, 1/32, 11. So 5/8x 11. Standard pitch, checked with a gage.
-You still haven't mentioned measuring the OD of the tap to confirm/deny the alleged oversize by 1/32.
H
Hal
Vermont
When I posted this, it hadn’t occurred to me to check the OD. I haven’t been back to the shop since. I will check later this morning a and post back.
rustyzman
Chicagoland
The profile of that tap looks like a Nut Tap. Long tapered lead in for production tap threading of nuts. Very low torque thread cutting because of that long lead in taper.
1/32 might be the diameter change from full thread depth to the start of the thread on that tap. That looks much too coarse to be a thread pitch for that tap, assuming that it is 5/8 diameter. The pitch looks closer to .100" or 1/10.
Now for some clarity, according to a little research here, that is a Very Old tap.
Wells Brothers & Co. was incorporated in 1879.
That changed to Wells Brothers Co. in 1888.
That tap is older than 1888 and newer than 1879.
That very much pre-dates the Unified Thread system (UNC, UNF, UNS, etc.)
5/8-10 is no longer a standard thread in the Unified Standard. That size and tap was from the days of everyone making whatever they felt was correct for the application.
A quick measurement of the OD at the thickest portion and at the very end will probably say a lot.
Winner winner
The 1889 Catalog shows these
I thought it said 10 at the top of your photo?
5/8 1/32 10 is what my eyes see.
rustyzman
Chicagoland
Interesting with the oversize. That is Seriously over sized at 1/32". I could see that if a nut was meant to be hot dip galvanized, perhaps.
