Unidentifiable tool
joepaintin
What is this for?
One-piece hardened steel tools with integral solid pilots (1/4”, etc.), large side relief window, conical and cylindrical pilot versions, no removable parts
J
joepaintin
The ones with the conical tip are Weldon 82deg per the stamp on the shank. The ones with the cylindrical tip don’t have a stamp marking is it a different manufacturer and different use? Who made them?
JuncleJohn
Omaha, Nebraska
Yep, I concur. Countersinks or chamfer tools, depending on your own terminology. Most would call them countersinks, a machinist or toolmaker would most likely call them chamfer tools.
Typically the 82 degree would be for an inch flat head screw and 90 would for a metric.
John
682bear
West GA
The ones with the pilot on the tip are used extensively in the aircraft industry to countersink for rivets and screws.
-Bear
cvairwerks
Within hearing distance of Texas Motor Speedway
As PC and OMR said, countersinks. There are two distinct types...the ones with no extension are simply know as "chatterless" zero flute c'sinks and the others are piloted zero flute c'sinks.
Those don't look to be in very good shape. I wouldn't use them if the c'sink was critical.
