Universal socket set made in Germany
ive
Canada
Hi.
Looking for a German set of universal socket sets. I can find the singles but not a set.
Also, any experience with any?
Dave455
Sussex, England
The philosophy of the German manufacturers is slightly different to the U.S. ones.
They assume their customers are predominantly professionals, and especially with the more specialised tools, they don’t offer so many pre assembled sets.
It’s really no problem, just order one of each of whatever you want, and you have a set!
Unlike some U.S. based importers, they don’t load the price of the individual tools, because they only want to sell sets. This is a more professional way to go about it.
Having said that, I find that a lot of German manufacturers, even those that are very competitively priced on more regular tools, are not such good value on the specialised ones.
I have used both Hazet and Stahlwille universal sockets, and they are o.k, but I think I prefer Snap On for not much more money, or KoKen for less!
^ In light of the overwhelmingly positive reviews here on the A/P stuff, it simply does not make sense to me to shell out that kind of money for Hazet or Snap-on.
More to the point: mentioned above - the "legacy" makers haven't changed the design of the tool to fill the needs of the current-day mechanic: too tall to get in the hole!
* I just shot a message to A/P asking for height dimensions on these pieces.
KnurledNut
n/a
It really depends on individual needs.
For example, an aircraft mechanic will likely want 1/4 drive SAE 12 point and that narrows the options substantially.
  • Like
Reactions: ive
^ Yes. Absolutely. Didn't even think about 6 point / 12 point - I was thinking overall height, which has apparently really become an issue in modern-day engine compartments - we didn't have "nano sockets" 20 years ago.
I would be curious to see how they "stack up" against each other in terms of the overall height of the socket itself.
  • Like
Reactions: ive
alinc100
Dearborn,MI
are we talkin' wobbly sockets? like this?
not trying to be too presumptuous, but why are you not looking at Astro Pneumatic?
membership here raves about their little 1/4" drive Metric flex socket set.
(yes, they also make SAE and other drive sizes as well, but that one is the only one I owned personally - now belongs to @Smokeshow69)
You are putting a lot of faith in ive to come back to this thread and clarify his needs. In the past IMHO he has asked questions, not responded and in a year asks the same question again. it's tough when we don't all share the same crystal ball and secret decoder ring.
  • Like
Reactions: ive
KnurledNut
n/a
I have noticed that too. I still try to contribute as it might help someone else. I also enjoy reading and learning from others advice. I am sure you would agree, this sub-forum has changed a lot over the years.
pfbz
I have the Astro 1/4" flex universals... Decent enough. What measurements did you need? Lots of Koken sockets as well, which are phenomenal, though their uni's are quite pricey. An alternative might be the Koken Zeal series sockets (extra short) and a Koken zeal universal. Won't be quite as short as a dedicated uni, but much better than a typical socket/universal joint combo.
  • Like
Reactions: ive
^ It is the overall height of the socket and ratchet together that has become the issue. It's for that reason we've seen the proliferation of "pass through" and "low profile" sockets over the last several years.
I shot a note to Astro Pneumatic asking if they could provide dimensions for theirs. The only u-joint sockets I have here are some old Indestro 3/8" drive SAE units, so they're not really relevant to this discussion.
  • Like
Reactions: ive
KnurledNut
n/a
Gonna be hard for anyone to beat VIM's dual drive universals height.
^ exactly my point.
I didn't even know those "VIM" models existed.
I just think there are other - and more likely better - options to look at other than "legacy" brands.
  • Like
Reactions: ive
pfbz
My Astro 1/4" metric set... 5-15mm
Astro 1-4%22 universal sockets - 4.jpegAstro 1-4%22 universal sockets - 3.jpegAstro 1-4%22 universal sockets - 2.jpegAstro 1-4%22 universal sockets - 1.jpeg
pfbz
I realize it's not what you asked, apples and oranges, etc. etc., but....
These days I'll rarely reach for a universal joint socket if it is any sort of low clearance situation. My go-to is the Astro 1/4″ Drive Low Profile Nano Impact Sockets (or 3/8" if bigger hardware), and if I need even lower profile, the Mountain/Icon/Platinum ratcheting wrenches with the lip on them are going to be *far* lower profile than even the smallest universal socket on a ratchet. And these measurements are with a tiny Koken 1/4" ratchet which is going to be on the smaller side.
Another plus, the Astro's are pretty inexpensive, great quality, and easy to work with if you ever have a warranty issue.
I
ive
Canada
Sorry bout that.
BombShelter
State of Hockey
I got the VIMs with the German Female Torx (E-Torx, or whatever it's called). The guy on YouTube had the same but he had rubber sleeves on his to keep them from rotating. Any idea if the sleeves are custom, off the shelf or an option?
If they're for engine work, there aren't a ton of low-cost options.
KnurledNut
n/a
Not sure what “sleeves” you’re referring to, but O-rings work well.
Astro Pneumatic said:
Below are the height dimensions you requested. Hope this helps!
Astro Pneumatic Universal Joint Sockets (aka "flex sockets")
7412
5mm 1.372"
5.5mm 1.395"
6mm 1.395"
7mm 1.398"
8mm 1.383"
9mm 1.383"
10mm 1.460"
11mm 1.440"
12mm 1.465"
13mm 1.515"
14mm 1.500"
15mm 1.468"
74310
10mm 1.784"
11mm 1.790"
12mm 1.804"
13mm 1.885"
14mm 1.860"
15mm 1.895"
16mm 1.895"
17mm 1.930"
18mm 1.970"
19mm 1.985"
