Unknown Arbor Press
rusty65
Pekin,IL
Import for sure use and abuse till she won’t squeeze anymore.
rsanter
visalia ca
Make the plate or look for a replacement for any brand you can get it for.
Only real difference will be the pin size and that’s easy to deal with
matt_i
Any help finding a bolster plate for it?
Depending on the job, a piece of something like 1/2-3/4" thick A36 steel will be just fine. Drill a hole in it for the job at hand. Also provides better support to what you are pushing on than the "U" shaped slot.
So along those lines you could drill a number of holes, 5/16, 7/16, 9/16, and on up which is provide clearance for 1/4, 3/8, 1/2" shafts....can drill a custom hole for whatever is being worked on right now.
