Unknown drill press
Patriot Squid
I am wondering if anyone may have a clue as to what make of drill press this might be? I am looking to locate a replacement spindle shaft for it. Is there a place that given the needed info can supply a spindle shat that would work?20211012_053650.jpg20211012_053828.jpg
shawhite
It appears to be a run of the mill import branded under a lot of different names. Unless it has some sentimental value I would say replace the drill press with a newer import of equal size.
FMB4
Is the actual spindle damaged or missing? Or do you simply need a replacement drill press chuck with a MT 2 (Morse Taper)? You can check this by (of course) rotating the handle downwards (you should see the spindle emerge with notches along the front or back of the spindle shaft).
