Unknown piston
wrench136
Found this at a friends house. All brass or bronze. From some sort of pump or ??
Any one know what it is ?
Roberts210
Missouri
My guess is it is from a very low RPM antique spray rig. Bronze so it wouldn't react with the chemicals being sprayed.
Debcrow
New Mexico
Do not know. The square opening reminds me of German 2 stroke transfer ports used in the 1950s. Since it does not have any rings I would say not for anything requiring compression. Because of that I would suspect some form of liquid as the medium. Very interesting
Skyman
Central Maryland
I have no clue, but it's fascinating. The connecting rod being offset from the wrist pin's axis is an interesting feature.
If it didn’t look used, I was going to suggest a HS class project, as it’s easy to cast. The E12 was how fifth period, student 12 would have marked his.
But low pressure, and low wear, due to the brass / bronze seems likely.
jgrickett
The brass or bronze says it's not from an internal combustion engine, and the massive construction of the piston says it's not intended for any sort of high-speed operation. That's just too much weight to be starting and stopping several times per second. The scooped out portion in the piston skirt says that it probably operated like a two-stroke, with that part sliding past two ports in the cylinder, one above the other. I'd say it's part of a piston pump, probably for a liquid, and likely a heavy liquid, judging by the lack of rings. That's as far as I can get.
