Unknown rail
seber
Deep East Tx.
This rail shows up in an estate sale ad for tomorrow. Can anyone tell me what this is for? Looks like a milling or grinding clamp but new to me.
laser3kw
northen IL
it looks like a machinist vee-block. The top part / horseshoe should be rotated and mounted 90° with the screw positioned above the "V" and the feet in the slots.
BFBOB
Right you are - I have a very similar setup. I think the beam on yours is rotated 90 degrees axially - it's made to clamp round stock in the v-side of it. The two-slot side (the top side in your picture) is to be fastened to the table via t-slot bolts. Mine is a little different - two short, almost cubical blocks instead of one long one. There should be two clamps, too.
I use mine on the drill press. It makes it much easier to cross-drill a round rod and get the hole centered.
darn laser beat me to the punch.
Kscardsfan
The Little Apple
Vee block, but I’m not near smart enough to tell you what a machinist would use them for. But I know that ammo makers and custom gunsmiths use them for accuracy and press testing in controlled environments.
As the others said, Vee blocks. I see a seam in the rail
I’ve never seen the clamp with the off center screw (edit: as seen in this link)
ItsNemo
Canada
V Blocks are used for clamping round items typically.
MushCreek
Upstate South Carolina
As others have said, it's a V-block, and the clamp is mounted 90 degrees off for some reason. I have several sets for doing round work. They hold a round piece precisely centered and square. I have tiny ones that mount into a larger V-block for doing really small stuff.
