Unusual uses for a press?
kenc184
Nor Cal
I have a small Dake hydraulic press (unfortunately chicom not REAL Dake) and of course I use it for pressing bearings etc in or out or for straightening bars, plate etc.
Here's one thing I made which is kinda foo-foo but it does solve a problem. The problem of throwing away that last tiny bit of soap on every damn bar!
I made a simple cylinder with a piston, save the old bits of soap up till I have a half dozen, then using parchment paper as a release agent I compress to about two tons and there you have it - a fancy round bar of soap.
What offbeat uses do you have?
Handyfarmer
in the high plains of Colorado
would not have thought of doing that,
I have considered making some kind of attachment to my log splitter for pipe bending, or making another system for the pipe bending and use the power pack on the log splitter for a power supply, I use the power pack to power my fence wire roller,
dr_clyde
Holland, MI
Huh. And here I just was putting the last bit of soap on top of the new bar all these years.
Neat.
purplezr2
Central MN
Thought of doing something similar for beer cans, make aluminum "ingots" per se. Easier to transport then 30 or 40 bags if I were to save them. I recycles them because it is easier at this point.
Cool idea none the less, if only I could do the same with that little bit of body washer in the jug.
2ndGearRubber
Pittsburgh
Neat concept - I just pitch that soap. It has lost its "soap-ness" and never seems to clean as well, nor integrate back into the new bar. Maybe use those discs for hand washing soap?
Finky198
North East
You do now :)
Rocking the Irish Spring are we me laddy.. very nice.
I use that at home and work in bar form great stuff. As well as Zep TKO.
I get quite filthy on a daily basis whether it chainsaw dust, concrete dust , or oil and grease. Those two soaps and the occasional squirt of dawn, keep me clean enough you would never guess what I do day in day out...
Aquamoose
Google Swag and you’ll get a few more examples.
redwrench60
East Tennessee
You do now :)
Yeah I use it too lol, I’m like you and get pretty nasty most days. It’s the only thing that really gets me that “squeaky clean” feeling. It’s not expensive or prissy so I always throw the “chip” away when it gets that small.
Ign
Butte Peak ND
I keep swearing I'll build a crusher for old aerosol cans, complete with a pin to poke 'em and a catch underneath for whatever drains out...
...but let's be honest, I'll never make the time
Jim C.
Not a bad idea.......:thumbup:
FakeNewsRealHP
Midwest
No picture right now but left over candle wax from the ladies scented obsession and dryer lint pressed into small discs make GREAT fire starters! Throw one in the pit under the small stuff and cover in split logs and light it and walk away.
2oolhound
BC Canada
I'm not sure how unusual this is but I know it's easier to just buy them
...but you'd have to have been thinking ahead in order to have them on hand when you need them so I just cut a small 3" length of pipe and chamfered the inside a bit then cut some 1/8" thick discs to press and used the round ball of a ball peen hammer to press the round shape to create some end caps for a hand rail I was making.
anndel
Hawaii, USA
I heard Hilton is going to start recycling bar soaps when people leave the rooms and make new soaps.
K
kenc184
Nor Cal
Great idea, I wonder if it would be easy to extend this idea to making end caps for Wilton vises? Just have to shrink a flange around the edge. Hmmmm......
2oolhound
BC Canada
It may be easiest to weld it onto a short length of the right sized pipe and then cut off just enough to fit in the vise.
K
kenc184
Nor Cal
That looks great, nice job. And I think you're right, that would be an easier approach on the endcap.
Copymutt
Colorado
Last fall we had an abundance of apples. I used my 12 ton press to extract juice for applejack. It was still labor intensive. The press did leave the pulp very dry however, so it worked well.
mike93lx
Richmond, VA
This may be cheating...
This press is used to make 5'+ diameter grinding wheels. 6,000 tons
mfewtrail
Give it a name and sell it on infomercials. . "The Soap Consolidator 5000." :beer:
tool_scrounge
Southern California
As a kid we had a 1 ton Dake arbor press with a ships wheel handle. It was great for cracking macadamia nuts. Just flick the ships wheel and the arbor would come crashing down on the nut, breaking the shell.
BFBOB
HF 20T (HHUS)
used it to straightn a vise drawbar. Worked fine, primitive fixturing.
