scootermcrad
Hey everyone!
I currently have a steep 12-12 pitch roof structure that is 2x10 construction. It is an unvented structure (for architectural reasons). We're ready to insulate and had actually planned from the beginning for this to be insulated with a spray foam system. Unfortunately Covid kind of through a wrench in that plan.
After extensive research on the best method/practice for our particular structure we found that 2" of HFO closed cell up against the decking and the rest filled out with batting to reach our total R value and then topped with a smart vapor membrane and then drywall was the best system. And it took quite awhile to find a reputable company to install that system. NOW that reputable company has completely gotten out of spray foam. I'm left to find someone (again) to apply this system and it's expected that the cost will be double the original quotes due to the times we're living in IF I can even find someone to put down HFO closed cell.
This brings me to the question or maybe just a concern. The reputable company I had chose said they have been doing damp application dense-packed spray-in cellulose for cathedral ceilings for many years. They essentially put a permeable membrane/net up and then they just spray it and build it up solid just like they would with spray foam and it gets in every nook and cranny. This is not like your big box store loose blow-in stuff. It's much more dense. They first use a single part spray foam to get any cracks and crevices to insure no leakage. The trick to making an unvented system work is to simply have no voids or chance of air making it's way in to the system. They tell me this will hold true with their cellulose application methods.
This company has been around a long time and has a great reputation for what they do. The price is SIGNIFICANTLY cheaper and I know this is a healthy product that won't off-gas or create other greenhouse type issues. My concern is the packed cellulose eventually breaking down and settling. I know it will have a slightly lower R value, but I'm not terribly worried about that and it meets building code. The price is extremely attractive (probably less than HALF or maybe even a THIRD of what spray foam costs will be at this point) and they are available to start when I'm ready.
Has anyone had experience with this cellulose method in a sealed cathedral ceiling? I'm always questioning what a "salesman" tells me and just want to do my research. There's not a whole lot out there on this method. So any experience from the pros would be appreciated. THANK YOU!
