upgrade for portable lights?
skipskip
Upstate NY
occasionally I need to work on a car in the driveway a distance away from the garage at night.
I have been using the 500 watt halogen work lights.
they are bright, but:
they get wicked hot
they use a TON of electricity
they never seem to light the area I need.
Is there a modern replacement for this?
Maybe a huge LED array?
Or some sort of compact florescents?
what other ideas?
Thanks
Skip
dankicksass
New Jersey
I had two of these 65W Cooper fluorescent work lamps for the past four years, says on the box it replaces a 500W lamp but like all CFLs the packaging greatly over estimates the usable output. Still pretty good light, maybe 350W equivalent. One quit working a little while ago, the ballast died and is not serviceable. Cooper warranty did not respond to my inquiry.
$65-75 at Amazon.
I have this on my wish list, a 52W poly lamp that uses four twin-switched 13W bulbs as found in nearly every CFL drop light I've ever seen. It says it outputs 250W equivalent and it looks okay to me. There are a bunch of reviews complaining about the features and price but it costs about the same as a Bayco 26W drop light in Lowes.
Under $30 at Amazon.
I've seen LED lamps but I don't put a lot of faith in them yet. I bought the 1000W standing lamp from the hot deal thread at Sears today. Energy costs will take years to catch up with the value in that kit at $20.
scuba0459
The Fundy shore off Nova Scotia
I have the yellow light that is in the above picture. I am happy with it. It has two switches so you can only run one tube if you want. They were on sale at Princess Auto in Canada but I can't remember what I paid but I think it was around $40.00
kbs2244
I have 2 four foot double bulb fluorescents with reflectors mounted vertically on old floor fan stands.
They have about 10 inches of vertical adjustment.
I got the idea from a carpenter.
The only real use I have found for the curly type CFLs is in my trouble light.
It is tougher than an “appliance” bulb and is cool.
mrb
i made this. 10ft stick of 1-1/4" EMT that fits perfect in a concrete umbrella base. at the top theres a bracket that attaches it to a junction box with 3 floodlight holders and a cord. I have 23w CFL par 38s in it, while not daylight bright it lights up a good size area.
Lansing, Michigan
mrb, that looks awesome! I was thinking of doing something similar, but with a 4' fluorescent fixture mounted on top of an old camera tripod. Now I might just give it a shot!
mrb
the bracket is an alumiunm piece (i had a bunch of them made) laser cut with a hole in the middle that takes a 1-1/4 EMT connector and has two holes that line up with the mounting tabs on the box. Couple spacers and the box bolts right to the bracket.
fflintstone
MOFnowhere Mi.
I bought some monstrous commercial tripod halogen lights of CL for cheap. They take both a 500W and 300W stick in each head (you can turn on either or both). Since I have no intention of ever plugging in 1600W or 3200 w for both tripods I am going to take them apart and put in some type of FC lamp in there.
