Upgraded my garage electrics today :)
ZRX61
Solar Blight Valley, SoCal
The lights & receptacles used to be on one of the house breakers & only the left side of this box in the garage was used. Today all the stuff on the right was added.
So now I have:
Left side is 20a/220v 1,Compressor, 2,Radial Arm & 3, 8in Jointer/planer & Tablesaw.
Right side:
Double 20a for all the lights (10x double 4ft flouros), GDO & 4x doubles on one side & 3x quads on the other.
15a 220v is the plasma cutter. (2 outlets 25ft apart)
2nd double 20a is 3x quads each side.
40a is for the Miller210 (2 outlets next to the plasma cutter outlets)
Did I miss anything?
Down Under Bloke
Top End NT Australia
My curiosity is getting the better of me, as standard power in Australia is quite deferent to USA
What’s the go with the paired up breakers is it for two phases or does it isolate the active and the common?
How does 220v work is it single phase or two phases at 110v.
bmwpower
Whole system is single phase. There are 2 poles (2 hots). Paired breakers tap into both of the 120v poles creating 240v.
Looking good, ZRX61
Z
ZRX61
bmwpower said:
There's an article floating around that electrical devices are actually driven by smoke. Generators actually produce smoke & pump it along the wires etc ....that's why they stop working when the smoke escapes.. :)
bmwpower
A-ha. I haven't read the article, but sounds funny.
Z
ZRX61
Here we go, I found it:
The Smoke Theory of Electric Circuits
Electrical Theory by Joseph Lucas
Positive ground depends upon proper circuit functioning, the transmission of negative ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work; we know this to be true because every time one lets the smoke out of the electrical system, it stops working. This can be verified repeatedly through empirical testing.
When, for example, the smoke escapes from an electrical component (i.e., say, a Lucas voltage regulator), it will be observed that the component stops working. The function of the wire harness is to carry the smoke from one device to another; when the wire harness "springs a leak", and lets all the smoke out of the system, nothing works afterwards. Starter motors were frowned upon in British Automobiles for some time, largely because they consume large quantities of smoke, requiring very large wires.
It has been noted that Lucas components are possibly more prone to electrical leakage than Bosch or generic Japanese electrics. Experts point out that this is because Lucas is British and all things British leak. British engines leak oil, shock absorbers, hydraulic forks and disk brakes leak fluid, British tyres leak air and the British defense establishment leaks secrets...so, naturally, British electrics leak smoke.
Subject: SMOKE
When wires smoke, how come the smoke is not the same color as the wire?
This is not completely true. When the smoke is in the wire, it is under pressure (called voltage). The pressure difference causes the color to change from the normal color we are used to. Not unlike the blood in our veins and arteries changing color due to the oxygen content. When the smoke escapes the wire and is exposed to air, the pressure is released, and the color reverts back to what we commonly recognize as smoke. The wire then changes to the color of the smoke that escaped.
I hope this helps you understand.
I would only question the last sentence of that description. It has been my experience that the wire turns a color directly opposite of the smoke.
Not always true, I think it must depend on the composition of the smoke in question.
I should have made it a little clearer; the color the wire becomes, is directly proportional to the escape velocity of the smoke. Higher velocities generate higher heat. This heat tends to burn the wire and affect the coloring. The statement was meant to be a generalization, indicating the fact that the color of the wire does in fact change. Sorry for the miscommunication.
I was speaking of electrical smoke which is generally white. The spent smoke casing generally assumes a color somewhat near black after the smoke leaves.
I can't stand it anymore! If, as you say, light bulbs **** up darkness and convert it to smoke which is transmitted (via wire) to a power source for recycling...why do car batteries go dead when lights are left on? Do car batteries (and flashlight batteries for that matter) have a limited amount of storage capability? Is it like a hard drive that gets so full that you have to double-space and then lose all data?
Now you're getting it.......
I thought you guys were smarter than this. Of course the battery stores the smoke. In fact it can store so much smoke that if you open the top and light a match, the resulting explosion can do serious damage. I'm sure you are aware that usually where there's smoke there's fire. If you connect the battery to a charger, the smoke is then returned to the wire (Remember, a light bulb wont work unless it is connected to a wire system) for the utility companies to use. Your hard drive analogy is a very good example.
Our hardware guys might be onto something in their quest for superior wiring. I have noticed the unique method of of series/parallel wiring the power strips on our systems seems to prevent the smoke from getting out of the wires. A "Smoke Loop" of sorts. In the case of the "smoked" workstation recently, you should notice that this was a conventional single power strip installation.
Since color is perceived by the cone shaped receptors in our eyes, and cones require more light that their rod shaped counterparts. Is the sky blue at night?
At night the process including contraction of the pupil is visual purple by which the eye adapts to conditions of increased illumination when facing 300 candle power redeflecting devices.
Since there is a spectrum of light that we as humans cannot see, I support the theory that everything is going up in smoke, we just can't see it. This may explain why the neighbors dog barks for no apparent reason.
I think your basic understanding of smoke systems is remarkable. However I find a flaw with your theory. The battery is a reusable storage device for smoke. therefore, one would assume that some sort of one way valve (we can call it a diode) should be needed to prevent pressure flooding back into the system while at rest. Unlike the A/C system, the smoke system is collecting darkness at the headlights and converting it to smoke. This causes the system to fill up. The battery can contain much higher pressures and volumes than the wires. If this pressure exceeds the capacity of the wire, it will cause a rupture as you described. The rupture can be controlled by a sacrificial device known as a fuse. But this still doesn't eliminate the problem. Perhaps a two way valve (zener diode) is used to allow a small amount of pressure to return to the system, and partially equalize. I find this theory unlikely though, due to the increase in the force required to start the pump (which is now under pressure) working again...
The smoke continues circulating through the system, due to the pressure differential in the battery (smoke pressure/vacuum reservoir). When the reservoir becomes depleted, the pressure simply equalizes everywhere in the system (similar to an A/C system when it's turned off) and stuff just wont work. Notice the relations: Work (W) = Force (F) x Distance (D); Force (F) = total difference in pressure (Dp) x Area (A). Therefore, the work done in a pressure system is: Dp x A x D. If the pressure differential (Dp) is reduced to zero then W = 0 x A x D = 0.
The smoke only escapes the wires when a path is created between the pressure differential areas (@ either the reservoir or the pump) that has too little restriction. When this happens, the smoke travels through the wires so fast that the friction between the smoke and the outer walls of the wiring heats the wires until they rupture. The smoke continues to escape until its pressure is equalized with the atmosphere, or until the conduit that provides the path between pressure areas is severed. When this happens, the sudden drop in pressure allows the wires to "collapse" slightly and, being so hot, as the edges of the ruptures and severed ends touch, the material becomes fused, sealing the system and retaining the remaining smoke.
Don't forget, when the system is at rest, all the valves, (switches and relays) are closed, keeping the pressure areas separated. When restarting the pump, as long as everything is OK, the smoke pressure is equal on both sides of the pump and there is no net force on the pump when it begins operating again. Also, within the pump there are pressure/volume actuated one-way valves with restrictors built in, arranged in such a way that they keep excess smoke volume recirculating through an integral smoke loop, which maintains the pressure within manageable limits.
The excess smoke, created by the light/smoke converters (headlights and other darkness absorbing devices), is changed back to darkness and dissipated in small unit concentrations so its dark effect is not locally observed. The smoke pump impeller (stator), converts smoke into magnetic flux which does work on the engine. Some of the excess work energy is dissipated through the cooling system and exhaust in the form of heat, while the remaining work energy is converted back to smoke and distributed evenly in small concentrations as you drive. This maintains the total quantity of smoke in the system at an average that does not change over time.
Z
ZRX61
I remembered the smoke part, but had foprgotten that headlamps etc are darkness absorbing devices that convert it into smoke to power other devices.. :)
mike944
Vernon, CT
Sounds a lot like the "dark-sucker" theory of light.
For years, it has been believed that electric bulbs emit light, but recent information has proved otherwise. Electric bulbs don't emit light; they **** dark. Thus, we call these bulbs Dark Suckers. The Dark Sucker Theory and the existence of dark suckers prove that dark has mass and is heavier than light.
First, the basis of the Dark Sucker Theory is that electric bulbs **** dark. For example, take the Dark Sucker in the room you are in. There is much less dark right next to it than there is elsewhere. The larger the Dark Sucker, the greater its capacity to **** dark. Dark Suckers in the parking lot have a much greater capacity to **** dark than the ones in this room.
So with all things, Dark Suckers don't last forever. Once they are full of dark, they can no longer ****. This is proven by the dark spot on a full Dark Sucker.
A candle is a primitive Dark Sucker. A new candle has a white wick. You can see that after the first use, the wick turns black, representing all the dark that has been sucked into it. If you put a pencil next to the wick of an operating candle, it will turn black. This is because it got in the way of the dark flowing into the candle. One of the disadvantages of these primitive Dark Suckers is their limited range.
There are also portable Dark Suckers. In these, the bulbs can't handle all the dark by themselves and must be aided by a Dark Storage Unit. When the Dark Storage Unit is full, it must be either emptied or replaced before the portable Dark Sucker can operate again.
Dark has mass. When dark goes into a Dark Sucker, friction from the mass generates heat. Thus, it is not wise to touch an operating Dark Sucker. Candles present a special problem as the mass must travel into a solid wick instead of through clear glass. This generates a great amount of heat and therefore it's not wise to touch an operating candle.
Also, dark is heavier than light. If you were to swim just below the surface of the lake, you would see a lot of light. If you were to slowly swim deeper and deeper, you would notice it getting darker and darker. When you get really deep, you would be in total darkness. This is because the heavier dark sinks to the bottom of the lake and the lighter light floats at the top. The is why it is called light.
Finally, we must prove that dark is faster than light. If you were to stand in a lit room in front of a closed, dark closet, and slowly opened the closet door, you would see the light slowly enter the closet. But since dark is so fast, you would not be able to see the dark leave the closet.
Next time you see an electric bulb, remember that it is a Dark Sucker.
DIGGER_DAVE
Calgary AB Canada
I'm STILL LMAO about ZRX61's "Smoke" explanation!
Down Under Bloke; the "ganged" breakers (at least in my part of the country) can be for a couple of things.
One - Any breakers controling DIFFERENT circuits in a common enclosure must use a "Ganged" - or - "Tied" pair of breakers. (common in "split" outlets; - divided 120 v, single phase recepticals)
Two - 220/240 volt, single phase circuits - made up of TWO 120 v, single phase HOT leads.
In both cases; it insures that the "smoke" :D going to that particular enclosure (or group of enclosures) can't escape. (or shock the hell out of you!!)
Multi-phase stuff gets a bit more complicated.
