7 x 300' equals 2100 feet?
6 x 300' equals 1800 which is fine. You don't want any to be under benches/tool boxes/ lift post ect.
I think my actual square footage is 1922 sq ft, just easier to refer to it as 1900.
Good point about the toolboxes. I’d considered that, but don’t have definitive locations picked out for them. And it would realistically only be a few feet worth of tubing saved anyway. Not to mention I was thinking it would end up making the Pex runs more convoluted with 90* bends to loop around the toolboxes than just running simple, straight lines right underneath the toolbox area. Not to mention if I ever re-arranged things later and ended up with a cold spot in my floor, I’d be cursing myself for not just running the pipe under the boxes.
I do have two 3’x3’ pads picked out for a 2-post lift, but that only drops the needed length by 6’ per pier pad, or 12’ total.
I’m also locating the manifolds and necessary control equipment, etc. in my basement, necessitating coring a hole through my foundation wall (it’s an attached garage). I was factoring in an extra 5’ of length on each end of each pipe to allow reaching the manifold. Call it 60’ if six loops or 70’ if seven loops.
A final consideration was running Pex at 6” OC for the outer most 2 loops around the perimeter of at least half the slab where my workshop area/lift will be just to fight the higher heat loss through the foundation wall.
1922+70 is darn near 2,000 sq.ft., plus the possible extra perimeter loop, and I really didn’t want to round down to 1800. My logic was that I’d rather take 10-15’ off the end of each length of Pex and end up with an extra loop with each being a bit shorter than have to pick a 150+ square foot region to not heat. Given all that information, do you agree with my plan for 7 loops?
