Upside down backward NPT tap.
Etchase
Hawaii
I found this in my tap drawer and I don’t know where it came from. It’s 1/8-27 NPT made by L.S.I. model 8156-A. I’ve never seen one like this, where the narrow end of the tap is on the shaft side. It’s 8 inches long. What’s it for?
E
Etchase
Hawaii
Thanks for all the help. It seems it is used (as Randall Thompson described so well below) in double wall boilers where it provides access and alignment, (2) general avoidance of obstructions like in a box, and/or (3) to utilize a single set up from one side, but needing a fitting from the other side. There is a tool for everything. It is not a bottom tap, nor home made or modified.
How do you buy one of these things?. I tried searches for back, pull, reverse, boiler tap and other terms to no avail. I can’t find L.S.I. Is it possible McMaster Carr doesn’t sell something?
oldtractors
Iowa
Randall is wrong. It is not a staybolt tap. I have no idea what it is for. The tap would have to be fed in from the far side, and if there is enough room for that long of the tap, it seems like there would be enough room to just use a regular tap.
E
Etchase
Hawaii
I believe what he was saying is that they used that particular tap to align the threads in the outer was accurately with the hole in the inner wall, not because the access was limited to the outer wall.
JSGAuto
Northern NJ
It could be custom (or semi-custom). We use machinery specific tool vendors for such things. You are not going to find it in a catalogue.
I can give them a sketch of a tool, have a quote in a day, and usually 2 weeks later have my custom tool.
