Upstairs floor?
Soccer918843
Upstate ny
So I have 14 wide opening attic truss down the middle. What are u guys using for sub flooring with prices so high? 5/8 Tg osb $32, 3/4- 43, cabinet grade plywood $37, advantech sub flooring $43, 3/4 plywood - $55
mike93lx
Richmond, VA
Really anything is fine. Many would use regular t&g osb, but I still like Advantech, glued and screwed
nadogail
Coronado, CA
I used OSB and where the end of the sheet fell short of the joist chord, I nailed in a sister, placing the junction on the sister.
This has worked since 1990.
mike93lx
Richmond, VA
Did you not start in the middle of the chord? Shouldn't need any sistering if so
