Is there any advantage to using conduit.
I am looking to run 2-2-2 AL URD from my panel to my subpanel in my shop, the run is 100' and I will be installing a grounding rod next to the shop. I dug the trench 18" deep, there is no code where I live. Is there any advantage to using conduit? If the cable is rated for burial then it seems like a waste, but my knowledge on this subject is pretty low. I know I have to install conduit on the vertical runs from the panel into the ground and from the ground up to the subpanel.
