Urethane a VCT?
C_J_GO
Sioux Falls, SD
Once spring hits here in South Dakota, I will be finishing my garage floor. At first I bought the peel and stick and thought a urethane coat over the top would do, but after reading some on here, it may not be such a hot idea.
Next option is VCT, but I would want a water tight seal, as winters here bring in snow, salt, and sand. I have a floor drain in each stall, so water movement over the tiles is inevitable. Has anyone put a one time clear coat (not wax) on their VCT floors? I would imagine that it would also seal in the color and not have the white tiles turn brown with tire wear. Any info is greatl appreciated.
SC-Eric
Spartanburg, SC
People do this all of the time. Our applicators have done this to entire grocery stores. It is best to use a product that is free of solvents. You don't want solvent to get under the tile and dissolve the adhesive.
SC-Eric
Spartanburg, SC
No... I would NOT use a urethane unless the VCT was going to take alot of UV... In general, urethanes don't have the bondstrength of a good epoxy. The epoxy should be a cycloaliphatic...
