G'day all,
Quick question... maybe someone here can point me in the right direction...
Playing around with a SIPS design for a project, but having some issues with the urethane foam, when I calculate it out based on expansion ratio and volume, I can't seem to get it right - either I get voids, bulging, or both... I've tried injecting into assembled structure (sealed and with holes to allow air to escape), as well as open pan then laminating the 'top' after expansion but before the urethane looses its tack.... the later however doesn't work, seem to loose a lot of its strength by being assembled during cure - and isn't workable for the actual project...
I've tried a few different urethane products now - and having consistently inconsistent results...
Is there a trick to this? Am I needing compensate for temperature?
