Bolster
Sailor Friend Asking for Diesel Help
I have an urgent issue, I need help from mechanics familiar with diesel.
My college roommate Reeves is single-handing (sailing alone) from San Francisco to Tahiti. He's currently mid-Pacific, another two weeks before he makes landfall if all goes well. He communicates to me via a low baud radio modem going out over single side band radio to a shore node that converts and sends to the internet.
I'm posting here because of the many friends I have on this sub-forurm that may be able to help; sorry if it's technically in the wrong forum but this is somewhat urgent and I want to post where my friends will see & can help. Mods please consider leaving the post here until I can get some answers to my friend Reeves. I'd not normally post here except the issue is urgent.
My roommate misremembers my youthful experience in the shop; he thinks I'm a diesel mechanic! (I wish-- I most certainly am not). He is asking me to contact his home shop, as well as "provide my opinion" of what the problem may be. The reason he needs the engine running is that he's now in the Doldrums (last reported position position: 03.18.990N by 130.28.187W) and will need to motor when there's no wind, which is often the case in that portion of the Pacific. Of course, the Doldrums is where the engine decides to act up. Also he's under heavy cloud cover and his solar cells aren't charging (they run communications & everything else electrical) so he needs the engine running for that purpose, too.
Frankly, I'm a little concerned for him.
The engine is a 1972 Perkins 4108, or possibly 4-108, or 4.108. Found a bit of info here: http://www.tadiesels.com/perkins-4108.html
In his own words now:
Boat: Murre
Make: Mariner 31
Engine: Perkins 4108, 1972
Previous, related work done: Oct 2010--I reported water in the oil (condensate and rust spots on oil fill cap); shop pressure tested the coolant system extensively and reported no leak in oil cooler. Dec 2010--From San Diego I report water in oil again. After discussions with shop, it is decided we should replace the raw water pump; no signs of water detected after...
Current Issue:
When attempting to start engine 10 days ago, engine would not start smoothly or immediately as is usual. Instead engine cranked for 10 seconds, only firing about half the time, and one piston sounded stuck for a few revolutions (this has happened two or three times in the last ten years). When engine did start, it ran fine and as per normal for the hour I used it to charge batts. Four days ago, same issue: failure to start easily but ran fine. On neither occasion was any water or anything unusual detected in the oil (I did not check the cap either of these times).
Today,
-Before starting the engine I checked the oil dip stick, and the oil was sludgey and clotted. Water was on the upper part of the stick and it had started to corrode. The oil was black, not milky.
-I checked the oil fill cap and saw water droplets under which there was rust.
-I failed to taste the water to see if it was fresh or salt or coolant at this point.
-The engine started roughly as per the last two attempts but ran as normal once started--I ran it for an hour.
-No unusual exhaust gas was noticed (not black, not white--clear exhaust).
-Water expulsion from exhaust system seemed normal.
-After shutting engine down, I checked cap where several large drops of water had formed (I'd dried it off before starting the engine). I tasted this water and it was FRESH (condensate?).
Related information:
-I changed the oil and filter in December 2010 and on April 27, 2011. No water was noticed on the fill cap or in the removed oil at either point nor the numerous times the engine has ran in between. In fact, the water pump change in December had seemed to solve the problem.
-Just after the April 27 oil change, I ran the engine for 20 plus continuous hours (motored La Paz to Cabo San Lucas) with no apparent problems.
-The heat exchanger was replaced in 2006; the oil cooler and coolant system tested in Oct; and raw water pump replaced in Dec 2010. What's left?
-I replaced the raw water pump myself and I notice that there is a very tiny oil seep under it. Is is possible I did a poor job of gasket placement and could that be the source?
-I am currently on passage between Cabo San Lucas and the Marquesas Islands:
-Seas have not been rough, but the boat has been in constant motion for over two weeks--could water have entered the engine via the exhaust system? (Again, I've sailed Murre in SF bay in much rougher weather for years without encountering this issue.)
-Weather has been hot and extremely humid for many days now, and the boat has received torrential rains on several occasions. Little or no water could have gotten into the engine room itself, BUT could the unusual humidity be effecting moister contents in the engine?
-I have five gallons of fresh oil aboard but only two filters (dumb)--so I can perform two solid oil changes and one more that leaves an older filter in place.
-I am in the doldrums (01.40N by 130.30W) and though have had consistent wind to this point, it is petering out. I may need the engine to keep forward momentum as early as tomorrow.
-I put the throttle lever in full reverse when the engine is NOT running, this to get it out of the way so that I don't sit on it and break it. Three or four starts ago I forgot to put it back in the upright position before starting the engine--then as I grabbed for it, a wave knocked me out of reach. Upshot: from a "cold" start, the engine revved all the way up (3 - 5 seconds) before I could get the throttle back to neutral. My current issues began on the next engine start.
Question:
-Can the issue be diagnosed from this email?
-What can be done while I am underway to protect the engine from serious damage and/or make it safely operable before next port of call.
-Baring resolution now, what should be done once I reach Hiva Oa (assuming there are any facilities there at all)?
Apologies for long email (just trying to be complete) and thank you in advance for any assistance.
Boat: Murre
Make: Mariner 31
Current Issue:
Today,
Question:
