US Style woodframe construction
Steevo
43.49600, -112.04300
Generally, we use "L" shaped anchor bolts that are sunk into the concrete wall or in the openings in the top of the blocks. The bottom plate on the stud wall is drilled and set down over the bolts, then washers and nuts tighten down to hold it in place.
Nowadays, building codes are requiring straps cast into the concrete as well, and they extend up the studs a couple of feet to tie the wall into the footing.
Here is picture:
Here is an explanation:
http://www.infoforbuilding.com/Footings_foundation_N.html
Falcon67
Merkel, TX
Typical for here is as above - 1/2" hot dipped galvanized "L" anchor bolts spaced no more than 12" from corners and 6' or less spacing on the perimeter. If you have already poured, you missed the boat on that. Anchors are set just as the concrete begins to set up in the forms - about 30 minutes after pour, or so. You can go back and hammer drill holes and use expanding bolts.
justanengineer
Motor City
Depending on age and location, it may only be gravity. In many cases the stud walls arent attached to the foundation in any manner, hence why so many houses slide off their foundation during tornadoes or hurricanes. If you google for images of New Orleans' 9th Ward after Hurricane Katrina you will likely find pics where the house is intact (tho damaged), but off the foundation.
cyamaha2007
St.Charles MO
Since you have already poured just build your wall set it on the footing then drill through the bottom sill of your wall and into the concrete footing. Now drive a expansion type concrete anchor in the hole. As you tighten the nut the anchor will wedge into the concrete.
blkhonda1991
Connecticut
Thanks for your reaction and info guys :bowdown:,
So I think if I build double brick walls with a 2" gap between, and than put in the anchor bolts and than fill the gap with concrete that must do the trick.
Also if I put some kind of layer like bluestone or something on top of the brick walls (for the looks) I have to make sure that rainwater can get away from the wood.
Is it necessary to put some sort of isolation between the bricks/concrete/bluestone and the wood ?
2" of concrete isn't going to give the bolt much holding power, there are typically min. coverages based on the size of the bolt. if this is a small shed probably not an issue, anything bigger you probably dont want to go this route. btw this is the typical detail for wood framed construction in the US.
cyamaha2007
St.Charles MO
Your wood wall will be flush with the outside of the foundation. So water running back shouldnt be a issue. Be sure to use pressure treated lumber for the sill plate and use sill seal.
pmiranda
Austin, TX
I'm curious...why the double-brick?
It seems like generally brick is only used as an exterior veneer these days, tied to the wood frame per code.
I'm guessing you need the lower portion of the wall to be rot-resistance inside as well as out? Maybe build it from concrete masonry units? I think you can still drill the footer and insert reinforcing bars to tie it into the CMUs, but I don't know what you need for your local codes.
JakeKohl
Greenville, SC
My structure was built with a poured concrete footer about 24" deep into the ground. Then a short cast concrete block wall (with mortar) was built. At the top of that short concrete block wall, galvanized straps were bedded into the mortar. The wood bottom plate then had holes drilled in it where the strap came through. The strap was then bent and nailed (multiple times) to the bottom sill plate. You can sort-a see a few of these straps in this photo (may need to follow the link and view the larger photo).
DSC_1971 by Team Seacats, on Flickr
DSC_2046 by Team Seacats, on Flickr
DSC_2647 by Team Seacats, on Flickr
